what valves to get kz9000
- wood9781
Im looking to put in ape 37.5 intake and not sure what I should go on the exhaust
I emailed pitstop performance for a quote on there valve job and valves waiting to find out what thats going to run me. . I live in Indiana and dont really know anybody around here to do the work.
what size exhuast valves should I go?
not sure what carb I have its a mikuni I measured the manifold side it read 1.25 inch / 31.75mm
- les holt
- Thank you received: 288
What part of Indiana?
Les
- wood9781
Attachment IMAG0067.jpg not found
lebanon In. heres a pic of the carbs, not rally sure what they are. I was told if I go with 37.5 intake it would help it open up a little.
- les holt
Truth is you need to speak to a cylinder head guy and tell him your plans. Each one has their own specific ways of doing things and can explain the whys and why not of larger valves.
I live around Kingman, use to work in Thorntown back in the late 80's. Played over there a few times, they had some good running stuff.
Les
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- DFIGPZ
- Thank you received: 122
1984 750 Turbo
- wood9781
are them carbs I have work on my bike good?
- LarryC
wood9781 wrote: I talked to a guy at ape, he said it would help it breath a little better that they came restricted from the factory. I will give the link above a call tomorrow and see what the have to say also.
If the bike is stock. If you're not making the motor bigger, the stock 36's are fine on the intake side. If you want new valves, Kibble White is what you want.
I prefer to use either J model 37mm or GPz11 38mm when going over size in a KZ900 / 1000 head. They're .050" shorter than the KZ aftermarket 37.5 intakes. That works big time in your favor if you have a stock 1.110" base circle cam.
Larry C.
- APE Jay
- Banned
- Thank you received: 58
- wood9781
So the 37.5 is not worth it?
thanks for the help guys, just kinda new to the kz's
- LarryC
wood9781 wrote: Its all stock motor Im not goin to put a buch of money in the bike, so should i still get a valve job done with the vavle guides amd seats since i already have them? what size valves should i get for the intake and exhuast.
Oversize valves require sinking the seat to keep the valves from tangling. For what you're trhing to accomplish, it's not worth the cost unless you intend to add cams and a big bore kit.
If you pull it apart yourself to do the work, open up the throats to 90% of the diameter of the intake valve or 32.4mm. By throats I mean the hole in the valve seat. It has to be blended back into the bowls.
When you don that, you'll take material away from the seat and the bowl, all the way around. Don't lay the short side [port floor] back.
When you look at the exhaust valves, you'll see they're seating way low on the face. That needs to be corrected also. Push the seat out on the face toward the top of the face. Open the exhaust throats to 89% of the diameter of the exhaust valve or 26.7mm. They'll be close to that already.
Here's a picture
Attachment throat.jpg not found
Larry C.
- wood9781
