sandblasting engine
  • Powerstroke_fan
  • Powerstroke_fan's Avatar Topic Author
Re: sandblasting engine
20 Feb 2012 21:49
#505346
no iam going to run it what do you think bout my previous post? and i know there is alot of people with bead blasted motors running around, i just wanna make sure i can do what i can properly before i do toast the motor.
1977 KZ 1000 work in progress
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
20 Feb 2012 21:57
#505348
Powerstroke_fan wrote: no iam going to run it what do you think bout my previous post? and i know there is alot of people with bead blasted motors running around, i just wanna make sure i can do what i can properly before i do toast the motor.
Like doubledub and LC said don't put it back together dirty. Not even if you think it's dirty. Get pipe cleaners to run in the oil galleys as far as you can, use lots of compressed air, degreaser, strong water flow, flush in BOTH directions and do it until you're positive it's clean before you assemble it. It will be okay in the end.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • notaduc
  • notaduc's Avatar
20 Feb 2012 22:17 - 20 Feb 2012 22:18
#505355
andy9802gt wrote:
notaduc wrote: I work at an engine machine shop. We only soda blast engines. We have a glass cabinet, but we never use it on anything that will contact oil, water, or intake air.
Soda does a fantastic job cleaning up oxidation, old gaskets, and anything else, plus you dont have to worry about contaminating the media. Well, that and yea, its water soluble. Plus its amphoteric and neutralizes most thinks that will corrode metal parts.
I honestly wouldnt risk installing any new parts in an engine that had been blasted with sand or glass... Id replace at least the head , you run serious risk of ruining parts and wasting your labor otherwise.
Actually, we do bead blast valves, but that is a different story.
I guess since they don't glass bead parts at the shop you sweep at, it shouldn't be done. You may convince the OP that glass beads are bad and that his head can't be voided of any residue from his sandblasting mistake but, I will not bite on your misinformation. My entire engine was glass bead blasted and properly cleaned and then cleaned again. Power stroke, if you believe that your head should be replaced let me know, I'll come pay you scrap value, bring it home, clean it and put it on the shelf for later use.
OP asked for "everyone's opinion".
My preference would be to never introduce anything that should it remain in my engine after assembly, would hasten wear.
It took a moment to process what "you sweep at" meant, I assume you mean I sweep all day, come down anytime, Id be happy to show you what I really do.
Why you have taken so much offense to attempt insults, I have no idea.
The thing that is obvious here is that where you are instructing powerstroke what to do, I am stating opinions, as asked.
Its funny, I posted a while ago mentioning that I was amazed at the lack of confrontational jerks on this forum, but I guess I found one.
1980 (mostly) KZ1000
Last edit: 20 Feb 2012 22:18 by notaduc.
  • Kawickrice
  • Kawickrice's Avatar
20 Feb 2012 22:21
#505357
I would load it up and take to the local car wash and pressure wash it, then blow with compressed air then oil it down before the rust sets in.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • zed1015
  • zed1015's Avatar
20 Feb 2012 22:21 - 20 Feb 2012 22:23
#505358
I built my own blaster years ago, I use Glass beads , aluminium oxide, iron oxide etc depending on the part and finish required.
Doesn't matter what media you use,thorough cleaning is the key.
Before blasting, the part should be de-greased.
Try and mask off or bung oilways etc.
With heads it is best to fit the camcover, I have a spare and some old cam end plugs i use for this and tape off the camchain tunnel.
This keeps almost all if not all blast media entering the head internals.
Most of the head is easily cleaned but it is the oil gallery to the cam journals that is the main worry.
Flushing through with hot soapy water gives good results as the detergent grabs and unsticks foreign particles.
If the head has been blasted without masking then the only way to be 100% sure that all the beads are gone is to remove the alloy bungs from the oil galleries so you can get a straight shot down them.
Last edit: 20 Feb 2012 22:23 by zed1015.
The following user(s) said Thank You: M357.5
  • Powerstroke_fan
20 Feb 2012 22:25
#505360
i dont wanna start anything over my question i know there is people would say i wouldnt do it, and to everyone there own but iam going to run it. i just want to do my best to get it all out before like i already stated i will clean it again for extra assurance.I will get some of those pipes cleaners and use another three cans each that should get it all. i just want to turn the motor over before hand and get the first good bit of oil out of the motor so its not going back in the crankcase, then i will run it complete
  • Powerstroke_fan
20 Feb 2012 22:33
#505365
i had plugs in them with the valve cover on. the plugs kept wanting to fall out, and i kept putting them back in. so iam sure some got in there but i didnt shoot it straight in or towards the galley opening without it being plugged. so it was just reckashay. and i used a parts washer with a pump and pumped diesel fuel thru the head on each galley multiple times in both directions then used brakecleen with compressed air both ways multiple times.
  • zed1015
  • zed1015's Avatar
20 Feb 2012 22:38
#505367
After the degreaser flush it out with hot soapy water (some degreasers leave a residue which will hold the grit) then finish off with the compressed air.
Good luck.
  • 750steve
  • 750steve's Avatar
20 Feb 2012 22:49
#505369
This is a soda blasted engine. Personally i wouldnt use sand or glass bead (we call it vapour blasting here), if either gets into the motor you're screwed. The difference with me is i didn't want to take my engine apart, if i was doing each individual component i'd be using glass bead.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • 893cv
  • 893cv's Avatar
21 Feb 2012 01:57
#505415
Powerstroke_fan,
I used glass beads when I cleaned the last KZ1000 head I worked on and the oil passages have lots of dead-ends that like to trap beads. I removed the aluminum plugs and cleaned the passages with a bore brush (I found the brushes at McMaster Carr). Please drill and tap the plugs with a 4mm tap and use a bolt/washer/socket to pull the plugs. I had cleaned that head after blasting ( I even ran it through the dish washer while my wife was out of town) just like you did and when I removed the plugs I still found beads. My one last tip is to tap the plug openings ( small openings 6mm, large openings 8mm) and use nice allen bolts and crush washers to seal it back up.
Good Luck!
1980 kz1000 LTD
1978 Z1R
The following user(s) said Thank You: BlackZ1R, M357.5
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
21 Feb 2012 02:54
#505435
Good post 893cv.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • Powerstroke_fan
23 Feb 2012 22:16
#506016
well i didnt want to pull the plugs so i had a idea. i just used a pressure washer with hot water and a high pressure jet. if 2500 psi dont get it out i dont think anything will. i sprayed it thru the galleys in both directions multiple times. but i will also clean in with pipe cleaner and more brakecleen before i install it.
