head cleaning
  • zed1015
  • zed1015's Avatar
  • Away
Re: head cleaning
20 Feb 2012 22:30
#505363
Walnut shells.
Very gentle.
Initial application - used for cleaning electrical components, Armature windings etc.
Re: head cleaning
20 Feb 2012 23:24
#505375
bluej58 wrote: That's awesome Ed.
What do you use ?
I spent all day yesterday going back and forth between engine degreaser and Simple Green .
That cut through the grim but I still have to take off the rust scales.
I'm using a red scouring pad and that is working pretty good, but I can't see it ever looking like yours at this rate.
I was thinking about baking soda, but now I think I'd rather have it a little dingy then risk having any trouble.
Depending on how much oxidation you are faced with you may want to select one or more grades of Nuvite polish. They use this stuff to make shiny airplanes. I have used their “S” grade and it works well if the surface is already smooth, but they have other grades for quickly removing oxidation if the engine is not already smooth. A little ¼ pound jar seems expensive but goes a long way.
www.aircraftspruce.com/catalog/cspages/nuvitenushine.php
I use S-100 Cycle Restorer polish and X-treem polishing wadding (see pics). The S-100 is a cream that can be applied to a bit of cloth and wrapped around a popsicle stick or other tool to clean and polish between the fins. The X-treem is ultra-fine wadding that works really well on large surfaces such as engine covers and a little goes a very long way; you don’t need to use a big handful. Both result in about the same level of shine. Cleaning and polishing an engine this way takes time and patience (and beer) but when once you’re done the engine does not oxidize again for a very long time, and it is really easy to maintain the clean shiny appearance. These products are pretty easy to find on the internet (and sometimes on eBay), but shop around as their prices do vary from place to place. Some bike shops carry them; that’s how I first found out about them.
Attachment ws-100metalpolish.jpg not found
Attachment wxtreemmetalpolish.jpg not found
  • bluej58
  • bluej58's Avatar
Re: head cleaning
21 Feb 2012 00:03
#505384
Thanks again Ed,
It looks like I might get away with G-6 followed by C
I'm going to talk to my buddy the pilot and see if knows of a source that's local .
JD
78 KZ1000 A2A
  • bountyhunter
  • bountyhunter's Avatar
Re: head cleaning
21 Feb 2012 02:26 - 21 Feb 2012 02:26
#505422
joe* wrote: Are scratches of no consequence? only the tolerance?
Scratches are big consequence. The camshaft surface should run on the cam caps surface. Large flat surfaces run a lot better than jagged ones. The other problem is how much damage was done in the process of getting scored that badly.
Last edit: 21 Feb 2012 02:26 by bountyhunter.
