i need some good input
  • testarossa
  • testarossa's Avatar
Re: i need some good input
29 Jan 2012 21:14
#500760
Dboy78kz1000 wrote: [attachment:1]C:\fakepath\IMG_0374.JPG[/attachment]
[attachment:2]C:\fakepath\IMG_0376.JPG[/attachment]
ok bout to take some more pic now and did u take any pic of when u did ur swingarm?
Sorry that I missed this question earlier. Yes I documented my whole build. Click the link that is in my signature line below. Hope you have some free time.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
29 Jan 2012 21:15
#500762
Plus consider what you plan do do with it when the work is finished. I don't know of very many 1375 sized KZ's being used on a regular basis on the street. Maybe others can chime in with their experience. Ed
  • DoubleDub
  • DoubleDub's Avatar
29 Jan 2012 21:18
#500763
mark1122 wrote: the sad part is that it doesn’t cost that much more for a bigger motor. 1300cc pistons only cost $3 more that 1075 pistons . The problem for u is that u need to get the stock parts healthy first, that means cam chain roller sprockets and the head work. Before u worry about big cc’s.
kzzone.com/
www.z1enterprises.com/Cam-Chain--EK-219H-122-link-1720.aspx
www.z1enterprises.com/Cam-Chain-Idler-As...y--Z1-KZ900-332.aspx
www.z1enterprises.com/Cam-Chain-Idler-Sp...000--Liska-2177.aspx
+1 - Going big is more than just putting bigger pistons and boring it out. You need a healthy motor first (minus pistons and bore). The head will be an expensive bit.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
29 Jan 2012 22:04
#500776
To do a 1375 would require a big block and custom pistons going bigger than 1260 in the stock block requires you to epoxy the big hole between the 2-3 cylinders back shut, and you still can't go past like 1335. 1075 is the most economical since you can run it with stock carbs, cams, and no head work if you choose. If you don't have $2500 minimum laying around just do a re-ring if the parts you have are in service limits. Probably wouldn't hurt to do a valve job while you're in there too, and if you're lucky you'll come in around a grand all in. Most of these guys will vouch that it ain't cheap to go bigger, I have around $3500 in my motor and already had the pistons from the p.o., but I'm also a retard and built it like a tank.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Dboy78kz1000
  • Dboy78kz1000's Avatar Topic Author
29 Jan 2012 22:46
#500784
im not working with that much cash so im just going to do a 1075. i dont no if i asked this befor but if i do the 1075 do i have to get my heads workd.
  • andy9802gt
29 Jan 2012 23:29
#500792
Dboy78kz1000 wrote: im not working with that much cash so im just going to do a 1075. i dont no if i asked this befor but if i do the 1075 do i have to get my heads workd.
1075 piston kit = @ $600
All timing idlers, rollers= @$400
Gaskets = depends on how far you go down past the base gasket but if replacing the cam chain @$200
Machine work for boring cylinders, checking cases, jug, and head for flatness = $??? Depends what you can get it done for
Valve job= again whatever you can get it done for
In my opinion even doing a stock cam, stock carbs, stock head 1075 you're looking at @$1500 on the cheap side of it. That's assuming all your valvetrain is usable, if not it just got more expensive. Don't forget to add in 3 oil changes, a couple sets of plugs, new jets for tuning the carbs for the new set up, new air filter/s, new plug wires/coils, new points or Dyna if you upgrade. It can get real expensive if things don't go right.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • DoubleDub
30 Jan 2012 00:23
#500801
andy9802gt wrote: 1075 piston kit = @ $600
On the money.
  • Dboy78kz1000
30 Jan 2012 01:27
#500810
i just want to be ready soon this weather break im tired of this snow. if i just get the pistons will that help? or i have to do all the above? i didnt no it was that much$$$
  • TexasKZ
  • TexasKZ's Avatar
30 Jan 2012 10:40
#500836
Dboy78kz1000 wrote: i just want to be ready soon this weather break im tired of this snow. if i just get the pistons will that help? or i have to do all the above? i didnt no it was that much$$$
Yes, it is possible to do just the pistons, but you will not be pleased with the results.
1. The carbs will need to be squeaky clean, re-jetted and carefully adjusted, because the engine will demand more fuel. Carbs that are in a poor state of tune or not perfectly clean will make for a poorly running bike. A really lean condition can burn a piston and destroy the whole thing.
2. Reassembling an engine with a questionable cam chain and related gear is very risky. If one of those parts lets go, a trashed engine is usually the result.
3. Leaky valves, worn valve guides and a poorly operating ignition system cause the engine to lose power and response. Obviously not what you are after.
Keep in mind that every addition of power puts additional strain on just about everything else. Every mod affects something besides the part being modded. When everything is working in harmony, you will smile. When various systems are in conflict, you will be disappointed and frustrated.
The guys who have posted to this thread are giving you advice based on a lot of experience. That experience includes more than one or two mistakes that they are trying to help you avoid. Keep asking questions, that's the least painful and expensive way to avoid mistakes.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
30 Jan 2012 11:32
#500841
I am in no way affiliated with any of the following companies except that they get my cold, hard cash.
To get an idea of the bucks you will be spending and for what go here:
www.redlinecycle.com/Engines%20-%20Components%20Index.html
kzzone.com/
www.z1enterprises.com/catalog.aspx?pid=KP441
and so, so many more...
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
30 Jan 2012 12:14
#500845
Save yourself some money and grief, put the bike back stock for now, even if you had a 1075 kit you wont be able to keep up with modern sportsbikes, even a gsxr 600 would blow your sox off, these bikes are great bikes but they dont handle or have the H.P. that modern bikes do.
1979 kz 1000 06 katana 750
  • Dboy78kz1000
30 Jan 2012 13:04
#500851
lol u got a gsxr 600 put u title where your mouth is!!! :evil:
