Oil fouled plug and low compression
  • Rickman
  • Rickman's Avatar
Re: Oil fouled plug and low compression
28 Jun 2006 13:04
#57801
russbernhardt wrote:
Any tips on how to properly clean these deposits without having to remove the valves?
Not sure how proper it is, but a bottle of Techron and some plastic scotch-brite pads are my weapon of choice.
I don't have a proper valve spring tool, but if that's the only way, then I'll add it to my shopping list (I've learned the hard way that the right tool is usually 90% of the problem solved).
You may not want to remove your valves, but replacing valve stem seals and checking valve guide wear may help you on your quest to solve the smoking cylinder.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
