What cams do i need?
- Kitten Tooth
Re: What cams do i need?
02 Dec 2011 14:20
Oh trust me, i know how to stop when i need to
especially when your in sioux city. i heard that the insurance rates here are the worst in the country. Nobody knows how to drive and im one to talk since i just got done rear ending someone doing like 40 a month ago:/ and thats another thing thats sucking my money away too, i have to buy the car i crashed since it was my grandma's. noby says i have to but seriously... i have to
i am going to have the head inspected before buying parts. Thanks for informing me about the valve springs too. what would you recommend with running 83-84 GPZ1100/stock cams? i always need the option to go back to stock if i want to... except for the metal thats going to obviously be shaved off the head
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
02 Dec 2011 14:21
and i do plan on bleeding the breaks and changing the pads, i had 2 people pull out in front of me last summer and one of them, i had to go up in a driveway and ride on the sidewalk and then hop back off again. he got some hand signs
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kraz1
02 Dec 2011 14:50Kitten Tooth wrote: I like going fast... I almost always touch at least 8000 RPM before i shift gears.
Well.... You're about 1800 RPM's short, on shifting to keep the rpm's in the peak zone for running your "Street Bike" down the Boulevard on One Wheel.. :lol: 9800 rpm's works better..
As far as "Ratty".... Who cares as long as it's mechanically sound..
Your only other concern for your bike as far as High Performance upgrade is the Clutch Basket. The guy who is going to do your Cylinder Head, will clue you in on the Clutch Basket Modification.
And I told him I would help you with anything you need for your bike. Send me a PM so I can send you a T-shirt.
02 Dec 2011 15:26 - 02 Dec 2011 15:27Kitten Tooth wrote: ...if there is no scoring on the cylinder walls should i get it honed anyways since it would be apart?....
Would hone the cylinder bores lightly to de-glaze them before reassembly.
And then wash the bores with soap and water, thoroughly water rinse, towel dry, and apply a thin covering of lightweight oil to the bores, all just before reassembly.
This should help the rings to seat, faster and better.
Last edit: 02 Dec 2011 15:27 by Patton.
- Kraz1
02 Dec 2011 15:55 - 02 Dec 2011 15:56
After Soap & Water wipe the Bores down with Fresh Cloth & Transmission Fluid. This will clean the Residual, the Soap & Water do not remove. Than repeat Soap & Water & Dry, and use whatever oil makes you happy for Assembly.
Last edit: 02 Dec 2011 15:56 by Kraz1.
- Kitten Tooth
02 Dec 2011 16:00
should i get the cylinders bored out or just honed? and the only reason i didnt push the bike up to redline was because of all the valve chatter. Spitting a shim is the last thing i need
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kraz1
02 Dec 2011 16:09
If you are Re-Ringing it, than you measure the Cylinder Bore to see if it is in "Spec" and can be Honed for New Rings. If not acquire another Cylinder that is in "Spec"... Or Bore what you have to the next size available that your wallet can afford.
However, if you continue to Run into people at 40mph you won't afford any of this for the next 3 years. :lol:
02 Dec 2011 16:14 - 02 Dec 2011 16:19Kitten Tooth wrote: ... 81' KZ1000LTD. The reason im even tearing into the top end is because...burnt valve stem seals/guides. The bike still runs like a clock but it keeps on fowling the plugs with oil after sitting a few nights. Its got about 130PSI compression on all 4 cylinders. I planned on honing and getting new rings too while i was in there but i dont know if i have the funding for boring it out and getting a piston kit...Should i not bother camming it unless i have the money for boring it out? As far as the cylinders go i was going to take it to a local machine shop for the honing. I have a paper with all their prices and for a V8, boring it out .030 over is like 17 bucks a cylinder. thats not bad in my opinion, but aren't Wiseco piston kits like 500 bucks?
I do run it at higher RPM too. I almost always touch at least 8000 RPM before i shift gears. I ride it like a drag bike....
Would consider just honing, along with the new rings, valve stem seals. and replacing any worn guides.
Also consider new valve springs, even heavy duty valve springs, because of the high rpm shifting, to help avoid valve float, especially in event of a missed shift.
Last edit: 02 Dec 2011 16:19 by Patton.
- Kitten Tooth
02 Dec 2011 17:18
Surprisingly in my car accident there wasnt too much damage by the way
i hate airbags, they just bitchslaped me for crashing and when the passenger one went off it shattered the windshield
oh well, its only an extra 180 bucks next to the 200 for the bumper, 50 for the headlight assy., and 150 for the fender... Good to hear that honing should be ok. thats only 8 bucks a cylinder. One more question, Z1 enterprises carries rings for KZ1000s that are 25 bucks a set (per piston). are those rings any good? i would much rather spend that then 50-60 bucks a set from Kawasaki.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
02 Dec 2011 17:27 - 02 Dec 2011 17:42Kitten Tooth wrote: ... Good to hear that honing should be ok. thats only 8 bucks a cylinder. One more question, Z1 enterprises carries rings for KZ1000s that are 25 bucks a set (per piston). are those rings any good? i would much rather spend that then 50-60 bucks a set from Kawasaki.
Would use the rings from Z1E.
And borrow or buy a dingle-berry hone to diy. They come in different sizes (diameter) and grits.
Perhaps someone can suggest the best grit size.
Some auto-supply stores such as AutoZone have certain tools available for loan.
Last edit: 02 Dec 2011 17:42 by Patton.
- tachrev
- Rubber Side Goes Down
02 Dec 2011 18:34 - 02 Dec 2011 18:34Patton wrote:Kitten Tooth wrote: ... Good to hear that honing should be ok. thats only 8 bucks a cylinder. One more question, Z1 enterprises carries rings for KZ1000s that are 25 bucks a set (per piston). are those rings any good? i would much rather spend that then 50-60 bucks a set from Kawasaki.
FYI, if you do hone it yourself, you don't just stick the hone in the bore and spin it around.
You want to create a crosshatch pattern in the cylinder.
It's best to have someone show you who has done it before, but basically you want to keep the hone steadily moving from the bottom to the top of the cylinder, then back again.
Don't just hold it in one spot, that will mess up the cylinder. The ones I've done I sprayed brake cleaner in the cylinder as I did it, kind of like a cutting lube.
There are probably other fluids you could use for this as well.
Build Thread
Build Thread
Last edit: 02 Dec 2011 18:34 by tachrev.
- Nebr_Rex
02 Dec 2011 21:04Kitten Tooth wrote: Oh trust me, i know how to stop when i need toespecially when your in sioux city. i heard that the insurance rates here are the worst in the country. Nobody knows how to drive and im one to talk since i just got done rear ending someone doing like 40 a month ago:/ and thats another thing thats sucking my money away too, i have to buy the car i crashed since it was my grandma's. noby says i have to but seriously... i have to
I.O.W.A. = ? out wandering around? :whistle:
Seriously thou,,dingleberry for a quick deglase and crosshatch,rigid will do a better job but may take more material out.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
