Could use some timing help, New guy here....
Re: Could use some timing help, New guy here....
30 Oct 2011 03:12 - 01 Nov 2011 00:02
#486025
Thinking it's not a good idea to run the engine with a stripped or damaged cam cap bolt.
Would assure every hole is clean and dry (no oil inside) before the cam cap bolt is threaded in and lightly torqued. There are other topics on cam reassembly techniques to help avoid stripping the cam bolt holes. And also about successful repair using thread insert aka timesert.
Where the bolt snapped off, hopefully there will be enough of the stub remaining after removing the cap to gain sufficient grip for removal. Might be able to tack weld a nut onto the stub which could then be used to turn out the stub. This being after the easy-out has broken off inside the stub. :pinch:
Good Fortune! :)
Last edit: 01 Nov 2011 00:02 by Patton.
  • loudhvx
  • loudhvx's Avatar
30 Oct 2011 05:00
#486032
The cam cap bolts take a lot of stress during cam removal/install. It's critically important to use a nut driver, and not a ratchet or any other wrench during cam install. If it binds, then you have to back off on the ohter bolts and try again to install the cam evenly. Also it's critially important that the cam cap bolt holes are clean and don't have too much oil in the hole. I usually wick it out with a rolled up paper towel.
  • Motor Head
  • Motor Head's Avatar
30 Oct 2011 09:30
#486040
Don't run it without the bolt in the cam-cap. Also get you feeler gauge set out and check those valve clearances!
Do you have a compression tester or you friend with the Tap/ Die set? Do that get some #'s.
The advancer, the smaller 13mm nut should Not be used to turn the motor, I posted to use the 17mm nut that is just behind it. Take the advancer off, by taking the 13mm nut/ bolt out. It has two main pieces besides the weights and springs. Those will separate, and this needs the cleaning and lubing. While the main stationary hub with the shaft is pinned at the crank, and can only go on 1 way, the moving inner hub can be put on 180 degrees out. So make a mark on the two pieces to make sure you reassemble correctly. See if you friend can also bring along a timing light to make sure of not just the Timing, you can use the Flashing of the strobe as a cheap Ignition scope. Watch the strobe as you Rev the engine, try it on each coil wire. Should be nice and steady at All RPM.
Are you sure you don't have a Kink in your fuel line, or a restriction from a filter, petcock screen, poor tank vent, etc? You can pull the fuel line off of the Tee at he carbs, and place a catch can under the line, turn the petcock to "Prime" and check the flow.
  • Banditz
  • Banditz's Avatar Topic Author
30 Oct 2011 12:57
#486068
Ok, trying the best I can and can NOT get the bit's of bolts out. Only thing I know to do is tap the part I can actually get to and use bigger bolts there..Would be around a 1/2" of thread at least. Was talking to my buddy and he said that would work fine..What do you guys think?
Also no kink at all in fuel line. Electric fuel pump that supplies plenty of fuel. Tank vent is great, petcock is band new and fucntions great.
  • P21
  • P21's Avatar
30 Oct 2011 13:19
#486071
can you take picture of this broken cam bolt?
Kawasaki KZ 1000 Police (2002) P21
  • Banditz
30 Oct 2011 13:44
#486073
Sorry, don't have one. but it's just broken by about 3/8" on the bottom of the bolt. That's the only part that broke. Hence why I cant frigging reach it! I have plenty of space on top of the broken bolt to tap and install a larger bolt. Yeah, it won't go as deep as the other one..But it will have around a 1/2" of thread. Thinking I will go ahead and do that today.
Would anything else be responsible for not letting the engine run at high rpms? I did by accident pull one of the plug wire's out but i reinstalled it to the best of my ability. thinking that would do it? Next time I start it up i will go ahead and check teh exhaust to make sure each cylinder is firing.
  • Motor Head
30 Oct 2011 16:35
#486100
Center punch the top of the broken bolt, a transfer punch works best. The use a reversible drill and a left hand drill bit. Probably come right out, threads intact if you are good. Maybe get a bottoming Tap to clean up the threads if just a few look damaged.
Otherwise there are lots of suggestions, and several posts on fixing the threads for the cam caps.
TimeSert insert, a solid piece of metal with both an inner and outer thread. The inner would be the same size as the bolt now, which is important because you want the Dowl in place to hold the cap in position. This is where it was originally machined for the cam bearings.
  • Banditz
31 Oct 2011 17:09
#486328
Ok...Just went out and checked the plugs. i ran the engine at the 6k "limit" for a split second before hitting the kill switch. then pulled all four plugs. The #2, and #3 cylinder both were different color's than number 1,and 4. leading me to think a coil is going bad.. Since of course 2,3 both are controlled by one coil. Also with a temp gun number 2, and 3 both run cooler on the exhaust pipes too! Cylinder 2 plug was white, cylinder 3 was a light red color.. Both other plugs were the normal dark brown color..
Will have a comp. tester before the days end, and also a timing light. Figure its about time I buy one anyway.
Also gonna be tapping and installing new bolts this afternoon for the cam lobe hold downs.
  • Banditz
01 Nov 2011 00:51
#486419
Alright, the cam bolt that broke is now fixed. I could not get the broken part out, so instead I just tapped the head to the next size up. That allowed me to just barely fit the little guides over the new bolt and get her down tight. NO WAY that baby is ever going ANYWHERE!
While i was in there for giggle's I went ahead and checked again..yep, timing is dead on when I look at it from the pics on here.
Also cleaned up that advancer deal. She now snaps back quick as can be. No more issues there!
STILL won't rev past 6k..and still having the issue with the weird spark plugs. Installed new one's and they did the same thing. Anyone have any ideas??
  • MFolks
  • MFolks's Avatar
01 Nov 2011 01:30
#486420
Condition of the sparkplug caps? They unscrew from the sparkplug wire and should test at 5000 ohms. New ones can be ordered at www.z1enterprises.com or the local dealer.
Tried a different brand of sparkplug?
www.gadgetjq.com/spark_plug_cross_reference_motorcycle.htm
  • Motor Head
01 Nov 2011 07:18 - 01 Nov 2011 07:23
#486448
"While i was in there for giggle's I went ahead and checked again..yep, timing is dead on when I look at it from the pics on here."
What were the Valve Clearances, You did check them when the cover was off again, right? Do you realize that if you need to adjust the valve clearance, the camshaft has to be removed to access the Shim? As they are under the cam follower. :whistle:
You should have them written down, post them.
Last edit: 01 Nov 2011 07:23 by Motor Head.
01 Nov 2011 08:57 - 01 Nov 2011 08:59
#486453
Banditz wrote: ... Also cleaned up that advancer deal. She now snaps back quick as can be. No more issues there!
Perhaps fuel starvation due to obstructed tank cap vent.
Could test run with fuel cap ajar to assure tank venting.
Possibly the carb float bowl vent lines are kinked or obstructed.
Is the engine "eight-stroking" at wfo in high gear? If so, might be too high fuel level in float bowls, or loose main jet, or too large main jet.
Good Fortune! :)
Last edit: 01 Nov 2011 08:59 by Patton.
