Engine Removal - What do I Need to Know?
Re: Engine Removal - What do I Need to Know?
23 Oct 2011 08:55 - 23 Oct 2011 09:03
#484852
PaulyWally wrote: OK. I got it.
I found the section in the service manual. It was right where 650ed said it was. My problem was that I hadn't first removed the clutch push rod. And that was preventing me from pivoting the transmission cover in order to clear the frame.
650ed wrote: you don't need a VIN to use the Kawasaki.com parts diagrams. Just go to "owners Info" and at the drop down menu click on "Parts Diagrams." Click "Continue" next to "Motorcycle." Select the year (1976) and CC (750) and click on continue. In box 3 of the drop down click on "Click here to chose."
But when I do that, it doesn't even list a 1976 KZ750. It starts with 1977. :huh: That's why I was trying the VIN.
Weird.
You are doing something wrong because it does show the 1976 KZ750-B1. Try again following my instructions.
Just go to "owners Info" and at the drop down menu click on "Parts Diagrams." Click "Continue" next to "Motorcycle." Select the year (1976) and CC (750) and click on continue. In box 3 of the drop down click on "Click here to chose." On the next page that appears under "Vehicle Information" click on "parts diagrams." That should bring up a new window for all the diagrams for the 1976 KZ750-B1.
Attachment kz750.jpg not found
Last edit: 23 Oct 2011 09:03 by 650ed.
  • stonemaster
  • stonemaster's Avatar
  • Sorry I wasnt paying attention
23 Oct 2011 09:41
#484856
they will also have a parts diagram at Bike Bandit for ya as well
jus ridin my Rickshaw baby, among other things
23 Oct 2011 16:31
#484915
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • gwolever
  • gwolever's Avatar
24 Oct 2011 14:36
#485068
Patton wrote: If engine removal is required --
Might prefer (using padding, old tires, soft grass, or whatever) -- after removing fuel tank, battery and sidecovers -- lay bike down on its side; remove engine mounting bolts (and anything else in the way); then lift the frame up and off the engine.
Good Fortune! :)
This is the way I would do it too. I decided to pull mine (1000) with a friends help and it was heavy as hell. We decided it would have been easier to use the method described here...but hindsight is always 20/20.
Had an even more difficult time getting her on the engine stand to work on it.
1982 KZ1000 CSR
