Can't get into 2nd gear. Need some advice quick.
  • gengomerpyle
  • gengomerpyle's Avatar
Re: Can't get into 2nd gear. Need some advice quick.
13 Sep 2011 17:07
#476435
when i took my sprocket cover off i put the shifter a little to high when i put it back together causing the shifter to hit the alt cover and not letting it shift into 2nd gear. you might have done the same thing i did.
Topper wrote: Hmmm... Yes I did. I had removed it (and the sprocket cover) to do a little aluminum polishing. But then I rode to town (about 45 minutes on the highay) without incident and it shited fine.
It was only after sitting in town for a couple hours that suddenly it wouldn't shift.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • Topper
  • Topper's Avatar Topic Author
13 Sep 2011 17:16 - 13 Sep 2011 17:17
#476437
I thought that might be what was going on, but the shifter appeared to clear the alt cover just fine.
Send in the clowns-theres got to be clowns-dont bother they're here.
I'll happily acknowledge my status as a complete and utter noob, but I hope I've not degenerated to the level of clown. Although breaking down twice in one day and getting stranded on the other side of town certainly made me feel foolish.
Trying to do what I can about the noob status slowly but surely. I appreciate the help.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Last edit: 13 Sep 2011 17:17 by Topper.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
13 Sep 2011 19:55 - 13 Sep 2011 19:57
#476452
Some times it helps to not only be moving but to have the oil up to temperature and add a few more revs into the equation.
I really doubt that there's anything wrong with your bike.
The reference to the clowns was not aimed at you Topper but rather the member who made the off topic post.
I'd like to remind folks, one in particular, that posts are to be on topic in the tech forums.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 13 Sep 2011 19:57 by KZQ.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
13 Sep 2011 19:59
#476454
I'm pretty sure the comment was not about you Topper. Hang in there.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Topper
13 Sep 2011 20:43
#476471
No worries all. The bike seems to be shifting now and I've moved on to the electrical problem that came up once I got it shifting.
1979 KZ750 Twin
  • Godfrey
  • Godfrey's Avatar
05 Oct 2011 22:49
#481598
well Topper I started reading this thread cause I just started having the same issue with shifting. When you pulled the sprocket coveror clutch cover off , is it possible you disturbed or disconnected the wires coming from the alternator, cause it sure seems funny that all of a sudden your battery went dead, and thiose wires were in the area you were workin in, I hope another simple fix for ya.
1981 650CSR frame
1980 KZ750E engine
  • Topper
06 Oct 2011 12:10
#481694
I thought the same thing. But it turned out to be a fried connector at the regulator.
1979 KZ750 Twin
  • Godfrey
  • Godfrey's Avatar
07 Oct 2011 19:13
#481912
Ok I guess its safe to highjack this thread then, goty the same issue with my 750, drove to my daughters went in and visited a bit, hopped on the bike and all I got was first and neutral, wouldn't go into second, was a mile from home, and it did shift into second and got thru the gears once on the way home but not since. I've removed the sprocket cover, sprocket and shifter cover, and so far the only thing I've found was the circle clip on 4th-5th gear shift fork rod was not in the slot on the rod. Like Topper it seems odd that I would have problems when it drove fine for several miles.
1981 650CSR frame
1980 KZ750E engine
  • Godfrey
  • Godfrey's Avatar
10 Oct 2011 22:40
#482447
well I put the clip back in place,and reassembled everything, not sure why it would effect 2nd gear but it seems to have solved the problem. Bike shifts fine now.
1981 650CSR frame
1980 KZ750E engine
  • Topper
10 Oct 2011 23:13
#482457
Glad to hear it!
1979 KZ750 Twin
