Z1 head porting
- wireman
- wireman
Re: Z1 head porting
16 May 2006 18:29
#@@!@#$$$$$#$# wrong size pictures!!!!!#@@@@&&&^^^*&^*^:whistle:
Post edited by: wireman, at: 2006/05/16 21:30
- wireman
Re: Z1 head porting
16 May 2006 19:29
yeah these pictures really suck!:S this was after the ports and chambers were coated.and yes these ports are heavily breathed on:evil:
Post edited by: wireman, at: 2006/05/16 22:36
- wireman
Re: Z1 head porting
16 May 2006 19:30
cumbustion chambers opened up for bigger bore,piston coat on chambers.
Post edited by: wireman, at: 2006/05/16 22:38
- wireman
Re: Z1 head porting
16 May 2006 19:31
this is how i do exhuast ports d-shaped flat on bottem opened up on top and sides to match port coming off of chamber.copied from big block chevy exhuast ports seems to work really good.this head came from one of my old 1170 motors i did 10-12years ago ran like a scalded dog well see on this motor.:evil:
Post edited by: wireman, at: 2006/05/16 22:44
- wireman
Re: Z1 head porting
16 May 2006 19:32
cant really see much in picture but extra ribs on front and back of ends where valve cover bolts on have been removed.corners on fins of gpz-j head are chopped off at angle started to round off corners removing sharp angle will look more like suzuki when done,lots more wittling to do and a little more glassbeading before valve job and assembly.
Post edited by: wireman, at: 2006/05/16 22:51
- wireman
Re: Z1 head porting
16 May 2006 19:34
pistons from the 1170 the head came from,i wanted to try the piston coat on the tops and anti friction coating on skirts of these before doing the big motor,the big ones are getting coated now!and yes that 1170 motor was put together with the pistons and rings and cylinders dry 12 years ago,no broken rings no scuffs and bore still is nice and round with no ridge
Post edited by: wireman, at: 2006/05/16 22:53: :evil:
Post edited by: wireman, at: 2006/05/16 23:01
- Mark Wing
Re: Z1 head porting
16 May 2006 22:05
steell wrote:
Thanks steell that is what I was talking about.
CrusingRam. Yes that's all I d tell someone to try on their own. Unless you really know what your doing you can rurin the flow by taking material out of the wrong aireas. My head work was done by a profesional engine builder and it's a bit more than just matched.
What I'm trying to say is if you don't have a flow bench or really know what your doing don't start just opening things up as big as you can go like a few guys were saying.
Mark seems to be talking about anti reversion, the exhaust port is 2mm smaller than the exhaust pipe.
IIRC, it's to prevent pushing exhaust back into the cylinder just prior to the exhaust valve closing due to harmonic impulse. AKA exhaust tuning.
Yorba Linda Cal.
Yorba Linda Cal.
- rammy
Re: Z1 head porting
17 May 2006 05:55
wireman wrote:
I will agree with you on that wireman.The "D" shaped exhaust ports are very very effenciant.My dad and uncle spent many hrs one winter(off season NHRA pro-stock)and perfected that style port on a flow bench in the mid to late '70s.
this is how i do exhuast ports d-shaped flat on bottem opened up on top and sides to match port coming off of chamber.copied from big block chevy exhuast ports seems to work really good.this head came from one of my old 1170 motors i did 10-12years ago ran like a scalded dog well see on this motor.:evil:<br><br>Post edited by: wireman, at: 2006/05/16 22:44
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- bangshift440rt
Re: Z1 head porting
19 May 2006 15:53
do the chambers need to be matched to the larger bore? i am putting a 900 head on a 1015 block and didnt think i needed to do this, also will this raise the compression more than it would with the 1000 head by using the 900 head? thanks, ryan.
