Could This be it?? Was: Stuck in Gear..
- davidnard
09 May 2006 18:24
Hey everyone,
this is a follow up post to my previous thread of "Stuck in gear...help this newbie!!" thanks to all for your patience and helpfulness in helping my diagnose my problem! I owe you all a beer.
BUt on the the problem at hand...lol
I think I *may* have found the problem...
I pulled off the clutch cover and the clutch and the driveshaft chain and found this bent piece of metal...I believe pieces of metal that are spring loaded are called the shift forks?? Maybe not...
those shift forks were in FRONT of that bent circular piece, but i put them behind it for picture purposes.
If that is indeed my problem, here I am, begging the kzriders Gods to help me figure out what that part is, and where I can get it. I'll also need to locate a new gasket for The crankcase I pulled off, and for the cover on the rear side (where the neutral? line runs in)...had to pull that off so I had leverage to get off the one bolt.
- davidnard
Re: Could This be it?? Was: Stuck in Gear..
09 May 2006 18:56
Me again, sorry :blush:
This is the other gasket I need, but I am stupid and do not know the name of this cover... any help on those above two parts plus this one would be gravy.
- RetroRiceRocketRider
09 May 2006 19:38
That is the shift drum plate.
It screws directly into the end of the shift drum, and there should be six pins behind it that insert into the shift drum itself.
You already know that the larger gasket is the clutch cover gasket, the other gasket is for the generator cover.
Since it isn't listed in your profile and you didn't mention it, and not knowing for sure what year and model bike you have, no one is going to be able to give you exact part numbers for that plate or the gaskets.
I'd recommend listing that type of info in your profile, that way you'll get quicker responses/answers and less questions as to what KZ you have.
Post edited by: RetroRiceRocketRider, at: 2006/05/09 22:38
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- davidnard
09 May 2006 20:43
Yeah, my model info would probably be helpful :blush: someday I'll learn, haha. Generator Cover, awesome thanks! I'll see if I can't track down model numbers myself, hopefully those gaskets won't burn too large a hole in my pocket.
- Willo46
09 May 2006 20:53
Z1 Enterprises shows a gasket set for $27. It's usually pretty tough and/or pricey to get the individual gaskets from a dealer. Z1 Enterprises is highly recommended to do business with, they'll get you your parts quick.
www.z1enterprises.com/detail.aspx?ID=1861
The shifter bit may be a salvage yard job unless someone has one. Do you have any motorcycle salvage yards anywhere about? Hey I just did a search on Ebay and this showed up: check out item 4639229231. Looks like it has a good setup.
- guitargeek
09 May 2006 20:57
How on earth does something like that happen? Missed shift?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- davidnard
- davidnard
09 May 2006 21:08
To be perfectly honest its probably my fault. First time out on the bike (or any bike), stalled it in like 4th gear, I may have just forced down on it too hard. Or maybe it was already damaged and my fat lug foot exacerbated the problem...Im just glad its a cheap fix
and thanks for the links Willo!
- Biquetoast
- King Jeremy The Wicked
10 May 2006 05:12
davidnard wrote:
That is unbelievable. I cannot comprehend how it could just "happen", no matter how hard you shifted.
Since you got answers on the gaskets, I'll add this about the part: Many of us on the forum have "cross-reference software" (me included, just not here at work), and we can get you a list of the different models that the part was used on. You can take that list, and either try to buy the part new or NOS (read: big $) from sites like bikebandit.com and others, or start scouring eBay.
Good luck. Stay confident, you *can* fix it...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- davidnard
10 May 2006 07:01
Biquetoast wrote:
[quote Since you got answers on the gaskets, I'll add this about the part: Many of us on the forum have "cross-reference software" (me included, just not here at work), and we can get you a list of the different models that the part was used on. You can take that list, and either try to buy the part new or NOS (read: big $) from sites like bikebandit.com and others, or start scouring eBay.
Good luck. Stay confident, you *can* fix it...[/quote]
Hey thanks for that site link. I already grabbed a complete gasket set off z1 enterprises, and I may grab that tranny assembly off eBay. Love that bikebandit though, I can hop on and find exactly what the part name is. I'm also planning on replacing all the bolts and hardware I've pulled, so that was an easy reference for the sizes needed.
- Biquetoast
10 May 2006 07:44
davidnard wrote:
I'm very fond of BikeBandit.com myself, but they are very pricey. I use them as a last resort when nobody else can get something, they prolly can...
It also occurs to me, judging by the language of your post, that you've not seen the parts diagrams on buykawasaki.com. I've been posting the pictures from there (previously not having known your model), but I didn't give you the link. So, here it is:
PARTS DIAGRAM
..and of course, the wonderful Ivar and kz400.com is a wealth or resources...
Enjoy!
Post edited by: Biquetoast, at: 2006/05/10 10:45
....Love that bikebandit though, I can hop on and find exactly what the part name is...
PARTS DIAGRAM
Enjoy!
kz750twins.com
kz750twins.com
- davidnard
