Oil Leak only at highway speeds
  • rcarver
  • rcarver's Avatar Topic Author
Re: Oil Leak only at highway speeds
19 Jun 2011 21:11
#458234
Great description Patton thanks...and it really does make perfect sense now.
The bike is down right now, waiting on new timing chain tensioner from APE.
But I am dying to know if tighting my loose exhaust bolts fixed the leak for good, I'll keep you posted and thanks for the tips!
1979 KZ650 SR (aka: Stella Blue)
19 Jun 2011 21:50
#458243
rcarver wrote: ...am dying to know if tightening my loose exhaust bolts fixed the leak for good....
If the oil leak isn't fully resolved, would clean the engine and allow it to dry, then spray foot powder around the exhaust ports (and any other suspected leak areas).
Then start the engine and observe where the oil leak stains the powder.
Get down close and personal to the engine, and use a flashlight if needed.
There might be more than one leak area.
If leak around an exhaust clamp persists even after snugging the clamp nuts, new copper exhaust gaskets are likely needed.
Good Fortune! :)
  • rcarver
22 Jun 2011 12:08
#458718
thanks Patton! still waiting on my new cam chain tensioner until I fire her back up and do the foot powder test.
  • rcarver
30 Jun 2011 09:47
#460261
Well got the timing chain tensioner installed so I was able to fire her back up and unfortunately the oil leak is still happening. I determined the oil leak is coming from between the head and bottom end.
My plan is to re-torque the cylinder head nuts...hopefully that will resolve the oil leak.
I'm all ears if anyone else has ideas.
  • Melynn
  • Melynn's Avatar
30 Jun 2011 10:28
#460268
My leak from that area was from a broken cam chain tunnel O ring. I don't know if yours is so equipped.
1978 KZ750 Twin (gone)
1980 KZ1000E Shaft (gone)
1993 Honda 750 NightHawk (gone
1980 KZ1000LTD B4 (fixing up
30 Jun 2011 15:24
#460303
rcarver wrote: Well got the timing chain tensioner installed so I was able to fire her back up and unfortunately the oil leak is still happening. I determined the oil leak is coming from between the head and bottom end.
Re-torque is a good idea.
As known, should be done on a cold engine (after sitting overnight is best).
:unsure: Could the exact leak area location be better pinpointed? Which side of engine? Head gasket? Base gasket? Tach drive? Cam chain tensioner? Exhaust port? Cam plug (half-moon)? Valve cover gasket?
If available, a photo might help diagnosis.
Good Fortune! :)
  • rcarver
30 Jun 2011 16:39
#460306
yeah I will take some images asap and post them.
  • rcarver
01 Jul 2011 13:57 - 01 Jul 2011 14:05
#460481
here is a shot of the oil leak...it is located right where the internal cylinder head bolt is located on the front of the motor. I was thinking about taking out the cams and re-torquing those bolts (along with all the cylinder head nuts) but the manual says it is only necessary during first tune-up after purchasing the bike new.
But I figure it can't hurt to re-torque them or can it?
I have completed the following in efforts to repair it:
1) full tach seal/housing rebuild, with new tach cable
2) cam end plugs not leaking
3) new valve cover gasket, valve cover re-torqued
4) exhaust nuts re-torqued
Attachment kz650002.jpg not found
Attachment kz650001.jpg not found
Last edit: 01 Jul 2011 14:05 by rcarver.
01 Jul 2011 14:55 - 01 Jul 2011 14:58
#460488
rcarver wrote: here is a shot of the oil leak...it is located right where the internal cylinder head bolt is located on the front of the motor. I was thinking about taking out the cams and re-torquing those bolts (along with all the cylinder head nuts) but the manual says it is only necessary during first tune-up after purchasing the bike new.
Won't hurt to attempt a re-torque on a stone cold engine (after sitting overnight), and best to not "loosen" any nut a little bit before re-torquing to spec. Betcha' they aren't loose.
Thanks for the pics, but can't really tell too much, because was expecting and wanting to see a dark spot on white powder.
Torquing exhaust clamp nuts often doesn't help where a new copper gasket is needed.
A new valve cover gasket often leaks unless the mating surfaces have been first returned to a perfectly clean as-new condition. This means not even a tiny speck of black residue remaining on any part of the surfaces.
A leak-down test may help diagnose and verify a possible leak in the head gasket.
And would do this before removing the head.
New tach drive inner shaft seal and new o'ring(s) around the tach drive case should rule out the tach drive as a possible oil leak source.
Good Fortune! :)
Last edit: 01 Jul 2011 14:58 by Patton.
  • rcarver
01 Jul 2011 15:56 - 01 Jul 2011 15:58
#460493
Good Fortune! :)
Sorry the pics are not clear but in real life it seemed pretty obvious where the oil is coming from. But as you said the pics are not very telling.
The surfaces were meticulously cleaned before installing valve cover gasket, confident it is not that gasket. Could however still be the exhaust connection, I have not inspected the copper gaskets there, yet.
Anyway moving into a new house this weekend WITH A 2 CAR GARAGE!!! So I will have the proper setup to take care of the KZ.
Patton...will take foot powder pics after I get setup in new garage.
Last edit: 01 Jul 2011 15:58 by rcarver.
  • rcarver
28 Jul 2011 20:12
#465566
So i finally got around to working on the bike again, been setting up my new garage/workshop.  I checked all valves, reshimmed as needed, and re-torqued all cylinder head nuts. And since I had to take out the exhaust cam I also re-torqued the cylinder bolt located in the timing chain well.  I followed the directions that came with my torque wrench and broke all the nuts loose first.
So far no more oil leaks!!
