10.25 on the street?
- mark1122
- Keep twisting it
Re: 10.25 on the street?
31 May 2011 13:16Rampage1967 wrote: Have you ever noticed those modern bikes are mostly liquid cooled & use much more advanced combustion chamber designs?? A lot those engines are also computer controlled.
X2
dont forget about that base gasket. it can thicker 0nes are avail to bring the compresion down if needed.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- micah
01 Jun 2011 15:23
Okay- next question is: MTC or Wiseco? They're both about the same price on Ebay....
- mtkawboy
04 Jun 2011 15:12
Ill go tell my bike that 10.25 wont work. Have you ever checked your advance weights to see if they are stuck all the way out from corrosion ? You either are way too lean or the advance weights are stuck. I ride over Beartooth Pass which is 11,500 ft with no problems. You would normally have more problems at sea level & less as you go up in elevation. At Daytona Bike Week you see plenty of big motors street ridden with serious compression & big block cylinders.
- otakar
04 Jun 2011 17:18mtkawboy wrote: Ill go tell my bike that 10.25 wont work. Have you ever checked your advance weights to see if they are stuck all the way out from corrosion ? You either are way too lean or the advance weights are stuck. I ride over Beartooth Pass which is 11,500 ft with no problems. You would normally have more problems at sea level & less as you go up in elevation. At Daytona Bike Week you see plenty of big motors street ridden with serious compression & big block cylinders.
That is what I said.:whistle:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- DoubleDub
04 Jun 2011 20:53micah wrote: Okay- next question is: MTC or Wiseco? They're both about the same price on Ebay....
They both have made pistons for quite a while and are good companies. It's personal preference or basically the same, as far as I've seen.
- Gman
05 Jun 2011 08:19
MTC or Wiseco? I had the same question 20+ yrs ago when I built an 1105 motor. At that time the prevailing thought was MTC was a bit more durable, say for road racing or endurance application since it was a bit heavier piston with longer skirts where as the Wiseco was a bit lighter, shorter skirts, more suited for drag racing.I don't know if this is still true or not. As has already been said, both are good companies that have been at it a long time. I would think if both companies have readily available replacement parts, rings, pins, etc, you can't go wrong with either.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- otakar
05 Jun 2011 08:38
20-30 years ago there were a lot of choices. MTC, Wiseco,RC Engineering, Yoshimura, Venolia, are just the ones I can think of. Every one of them are good. The main differences between them are that some were forged and some were cast. Some used wrist pin clips and some used buttons.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- dshelly
05 Jun 2011 08:38mtkawboy wrote: Ill go tell my bike that 10.25 wont work. Have you ever checked your advance weights to see if they are stuck all the way out from corrosion ? You either are way too lean or the advance weights are stuck. I ride over Beartooth Pass which is 11,500 ft with no problems. You would normally have more problems at sea level & less as you go up in elevation. At Daytona Bike Week you see plenty of big motors street ridden with serious compression & big block cylinders.
Hey mtkawboy , dshelly over here in Belgrade. Sounds like we both better stay away from denver or our bikes won't run. I also run the 10.25 Wisecos with a set of bored out Mikunis rus great. So, Gman Run whatever pistons you like better. From what I have heard, Wiseco has some quality issues a while back. But I've never had a problem with them.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Old Man Rock
05 Jun 2011 10:26
If she's jetted correctly and your cam/ignition/timing is sport on, I believe you should have no problem running that configuration.
Hell, if I can run here in AZ, these ole girls should run anywhere within reason.... :blink:
Phoenix elevation ~ 1100 feet...
Summer Heat ~ 105 -> 115F
Payson AZ elevation ~ 5000 feet
Summer Heat ~ 75 -> 85F
Wiseco kit @ 10.25:1 1015cc
Webcam .365 cams
Keihin 29mm CR Specials
Runs up the mountain (~5000 feet) or during extreme heat index, I just tweak the slow jet screws out (CCW = leaner) ~ 1/8 -> 1/4 turn all is good.
OMR
Webcam .365 cams
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mtkawboy
05 Jun 2011 15:09
Dshelly do you know Craig Pinkston ? He sold his 74 Z1 & hooked me up with a California guy that I sold my 2 73 Z1's to ? Works as a butcher at Costco, has a harley and a zx14 now. Dont know if hes in Bozeman or Belgrade
