- Thank you received: 1
Removing valve spring without removing the head?
- BARNEYHYPHEN
1) hook up compressor to #1 & #4 and pressurize both pots at 100lbs PSI, to hold the valves closed. Would it hold at TDC or would the pressure push them down to BDC? Are both Valves closed at BDC?
OR
2) take #4 to BDC, remove plug and feed in say 50' of string/cord, through the plug hole then rotate #4 up to "compress" the string/cord against the valve?
Anyone ever done either? Thoughts? Thanks.
- loudhvx
- Thank you received: 1615
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- rammy
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- Duck
- e vica na i sau na ga
I've been getting a good bit of practice.
How are you going to compress the springs once you get the valves corralled?
Why do you want to remove the #4 springs?
If a tree falls in the woods...
- BARNEYHYPHEN
Duck, I know, I know. Just pull the damn head off AGAIN. Then maybe, THIS TIME, I'll be tempted to actually pull the block and go look for the broken oil ring on #4 I KNOW I've got.
Why didn't I do that 3 weeks ago, when the head was off? Huh, Huh.
Looking for a blameee. Anyone?
- rammy
- BARNEYHYPHEN
I've got 1,2&3 running right on the damn money, absolutely NO smoke, tan plugs....then there's #4!!!!!!
Doesn't smoke immediately on startup. Starts smoking after about 1 min then pretty heavy until 20 miles when it calms down to about 50% of what it was during the 1st 20 miles.
I know i'ts the oil ring on #4. I'll be gobsmacked when I get back in there and find it isn't? I just cant bring myself to take another day and a half to rip the thing back down and put it back together.
Doesn't have a little door hidden away somewhere, just behind pot #4, that you can change the rings through, does it?
- Duck
You should be at book rate by now!
- roy-b-boy-b
- Thank you received: 103
I don't see how a oil ring would make a cylinder smoke. Have you tried "Ring free" from Yamaha? It's great for freeing up stuck rings and removing carbon.
- tjk
FIDO
- tjk
FIDO
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
1979 kz 1000 06 katana 750
