Problems going at highway speed
- wyldchyld69
14 May 2011 18:59
I have a 79 KZ400 LTD that is in very good condition. The bike does very well at normal city speeds. But when I get it out on the highway something very wrong happens. It always starts when I get at least 70 MPH. First its as if I had a govorner, it looses power and slows down alot. The bike responds as if I completly throttled down, even though I didnt. Which was not cool as I was on the highway and other cars behind me wanted to drive at 70. I get it going back again and back up to the speed limit and it just completly dies. I coast to a stop on the side of the road and spend the next 15 mins letting it sit. Then with much trouble she finally fires up, and I drive home slowly. Speeds under 65 and she runs just fine.
This exact senario has happened twice, once before I tore apart the carbs and once after. I thought it might be the problem but its not. It now runs as it did before.
I have no reason to win land speed records but I would really like to be able to do the speed limit. Can anyone out there tell me why the bike would only have problems at 70MPH?
- Proxy
- 80% Human 20% Nuts/Bolts
Re: Problems going at highway speed
14 May 2011 19:08
My first inclination would be fuel starved. Clean petcock bowl and tank screens. New inline filter and make sure the gas cap vent is working.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- MFolks
14 May 2011 19:15
Tried replacing your fuel lines? I've read somewhere the Gas/Alcohol mix will swell up rubber fuel lines restricting the flow, maybe why your bike acts like this.
14 May 2011 19:45May test by running with fuel cap ajar.Proxy wrote: ...make sure the gas cap vent is working.
- Nelson
14 May 2011 22:38
sounds like fuel to me too. maybe tank is full of crud?
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- TeK9iNe
- What did you do!?!
15 May 2011 14:46
All good input thus far...
Maybe check your electricals/ignition system connections to see if they are maybe starting to vibrate with high wind...?
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- wyldchyld69
20 May 2011 00:05
I actually just replaced all the fuel and vacume lines reciently when I rebuilt the carbs. New inline filter is an easy kill, I can do that one Saturday. How do I tear apart the petcock? If I run it with the gas cap open what change will that make? what do I need to look for?
- elfmagic17
20 May 2011 00:38
I kept having the exact same issue with my Honda CB360, would run fine for 5 to 10 miles then start slowly running out of power, then stall, I finally thought to pull one of the fuel hoses loose and see if fuel was comming out when I opened the petcock up, Nothing!! I had found the problem. I took apart the fuel petcock bowl and found the screen was plugged with rust, used Iron Out (TM) and a little water with a old tooth brush to scrub the rust out.
Kenny Hicks
74 Honda CB550
74 Honda CB550
20 May 2011 00:40wyldchyld69 wrote: ...If I run it with the gas cap open what change will that make?....
Allows fuel tank to vent even if normal cap venting is blocked.
Insufficient fuel tank venting typically causes fuel starvation.
- wyldchyld69
22 May 2011 10:31
So I tore apart the petcock, used rust remover to pull off the gunk. It was pretty clean But I hit it good anyway. Pulled all the plastic and rubber away from it, cause it will eat anything non metalic. I also ran a guitar string through the vacume intake to make sure that was not plugged. Put it back together and fired it up, ran like a dream until I got it up around 65 and it started bogging down. Tack needle started to bounce around 6 grand, then it stalled. Same as before. So at least I diddnt make it worse.
I have not tried running with the gas cap open yet. I am going to try that today. If it is the fuel tank vent that is the problem can anyone tell me where the vent is? Is it in the cap?
- donthekawguy
22 May 2011 10:53 - 22 May 2011 10:54
Run it with the cap closed and a spare key in it. When it starts to bog down reach down and open the cap. Give it time for the gas to get to the carbs. BTW make sure you dont have a full tank or you will be wearing most of the gas that flies out.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 22 May 2011 10:54 by donthekawguy.
- KZQ
- Administrator
22 May 2011 11:01wyldchyld69 wrote: ...I have not tried running with the gas cap open yet. I am going to try that today. If it is the fuel tank vent that is the problem can anyone tell me where the vent is? Is it in the cap?
Classic plugged cap vent.
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
