12 - 12.5 compression ratio in KZ1000P?
04 May 2006 09:37 #45039 by Zthou1977
12 - 12.5 compression ratio in KZ1000P? was created by Zthou1977
Hello all,
Haven't been here for quite a while, but _really_ like the new look of the site!
Anyway, on to the question:
I saw a KZ1000J cylinderblock on offer with Wiseco high-compression pistons. Compression ratio is between 12.0 - 12.5:1. The seller is a well-known Dutch go-faster merchant, and tells me that with 98 octane this will run without detonation problems. However, I searched the forum and read that the J model doesn't respond well to higher compression ratios. It does seem a bit high to me...so: what do you think? At 100 euros for the complete set (block, pistons, rings) it seems too good to pass up...or too good to be true.
Jeroen
1982-1986 KZ1000 Police in black/no fairing
1977 Z1000A2 streetfighter
Moto Martin Z1000 in pieces
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
04 May 2006 13:09 #45090 by Kazilla
Replied by Kazilla on topic 12 - 12.5 compression ratio in KZ1000P?
What size is the piston kit? Is the cylinder block a stock Kawasaki unit or aftermarket?
One thing to concider is how you're going to start a big block kawi with 12.5 to compression.....
You'll have to retard the timing for starting or your stock starter won't do it.
04 May 2006 14:52 #45115 by Zthou1977
Replied by Zthou1977 on topic 12 - 12.5 compression ratio in KZ1000P?
Hello Kazilla,
The block is stock Kawasaki, the pistons are normal size.
04 May 2006 15:23 #45125 by Kazilla
Then it's just the starting issue you have to deal with.
If you used a thicker head gasket you might be able to get the compression down to where the starter would work. You could buy an iginition controller to retard the timing but they're expensive for a street machine.
You could always have the tops of the pistons machined down so you're in the 10 to 1 compression range.
Thicker gasket is the way to go. 12.5 to 1 is too high for a street bike anyway....
Good luck
04 May 2006 15:33 #45128 by Zthou1977
Hello Kazilla,
So a thicker head gasket would be enough to get it just working, or would it make it streetworthy (reliable) as well? Where can I get these? I didn't know there are different thicknesses, I have always ordered just by part number.
Machining would mean considerable additional cost, and because I do not know who I can trust with this in the Netherlands, I would like to avoid it.
04 May 2006 16:04 #45132 by Kazilla
There are many places on the Web to get thicker head gaskets. With thicker head and cylinder block (base) gaskets you should be able to get the desired CR.
I know that APE (aperaceparts.com) carries at least .43 copper head gaskets. There are also spacer that you can put under the cylinder block that will raise the cylinder there by putting the pistons lower in the sleeves and reducing compression. I sure APE carries cylinder spacer also. You can also find thicker head gasket on the Web by searching for "copper motorcycle head gaskets".
Do you have a picture of the pistons so we could see the domes?
04 May 2006 18:02 #45153 by 77KZ650
Replied by 77KZ650 on topic 12 - 12.5 compression ratio in KZ1000P?
a stronger starter would help too, isnt there a honda one that works?
07 MDP Rookie of the Year
04 May 2006 19:02 #45169 by Kazilla
Don't know about another starter that fits the KZ1000....
04 May 2006 20:24 #45189 by steell
Replied by steell on topic 12 - 12.5 compression ratio in KZ1000P?
Honda starter in KZ1000 thread
Lists Honda models to get the starter from, along with links.
Post edited by: steell, at: 2006/05/04 23:25
05 May 2006 16:03 #45356 by sbjones
Replied by sbjones on topic 12 - 12.5 compression ratio in KZ1000P?
ok. this one i got to hear about. i am going to pay close attention to this subject.
now. can a 1075 with 12.5 to 1 compression be run on the street with 98 octane gas?
will this run hotter? i want the most power i can get out of my 1075 and still have it streetable or right on the edge of street and strip ( riden but riden hard 90 % pf the time)
thanks
05 May 2006 16:45 #45367 by 77KZ650
you will have to carry octane boost with you if you want to fill up at a gas station
more compression=more heat I believe, just get a bigger oil cooler ;)
  • Duck
  • e vica na i sau na ga
05 May 2006 20:45 #45416 by Duck
Replied by Duck on topic 12 - 12.5 compression ratio in KZ1000P?
You might drill a small hole through the head at each cylinder, couple each hole to a ball valve, gang the valves and have a compression release similar to the high comp thumpers.
