So I got my head resurfaced.. and 3 \"free\" heli-coiled exhaust stud holes
- Trav
But I didn't think about the fact that the lower 4 exhaust studs stick out lower than the surface of the head, thus needing to be removed in order for it to be resurfaced.
So the machine shop removed them for me, and broke three of the four studs. They told me I would have broken them too.. guess I'll never know. They did totally remove and heli-coil the 3 that came out rough though "on the house". Technically a heli-coil makes it stronger than stock.. but man one of them really looks like shit, way down in there with enlarged bare alum threads all torn up.. hopefully there are enough threads down in there and it all functions as stock.
Otherwise, I'm really gonna be flipping pissed!
The valves and head do look nice though otherwise. I think they took around 4 or 5 thou off the head. Hopeing that isn't enough to effect anything like cam timing or compression too much. The block is getting resurfaced at APE when it gets bored as well..
- guitargeek
- Thank you received: 50
Any word from APE on when your bore job will be done?
Man, your bike's gonna be shit hot when all this is done!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- Willo46
- Snakebyte
- Thank you received: 2
4 -5 thou should not make a significant change to cam timing or compression. On the cam timing, if you look at the geometry of the cam setup, reducing the distance between the crank gear and the cam shafts 4-5 thou will slightly retard the cam timing, maybe 1 to 2 degrees. 4- 5 thou will result in very slight compression increase but probably not any more significant than all the other factors.
If you retard the timing on the chain you will lower the compression due to the intake valve closing later to build compression. Unless the cam is profiled to close the intake before BDC.
- Kazilla
If you're not changing the length of the cam chain and not changing the position of the cam sprockets on the cams how is the cam timing going to change when you lower the head.
As long as the relationship of the sprockets (crank and cam) don't change the cam timing should not change????
That's assuming you're using stock cam sprocket and not adjustable cam sprockets.
I'd think that raising or lowering the head in relation to the cylinder would only have an affect on the compression?
- BARNEYHYPHEN
- Thank you received: 1
Is this right? Anyone?
- Kazilla
This is assuming that the cams were reinstalled in the same position as they were before the head was milled.
Still not sure if I'm looking at the correctly.
But either way if you're looking fot a performance pickup put a set of APE slotted cam sprockets on the cams and set the cam timing at 112 EX. and 110 intake......
- BARNEYHYPHEN
Imagine taking say 1" off the head not 3 thou. Makes it easier to get your mind round? EX cam sprocket moves 1" closer to the crank sprocket, by "rolling" down the chain? 3 thou wouldn't be enough of a shave to allow you to move the cam sprocket to the next link on the chain?
Anyone? Thanks.
- APE Jay
- Visitor
If you have the cams sitting a certain height from the crank, with the front of the chain tight, and you lower the cams (mill the block or head), in order to keep the front of the chain tight, you would have to rotate the cams backwards ( or rotate the crank forwards).
Jay
- Kazilla
Just couldn't quite see it until the bit about the drive side of the cam chain....
Again this why there are APE slotted cam sprocket, we can set the timing where we want it....
Thanks Jay.
- Trav
Barney you got it finally there. I would have jumped in but this website never emails me when a post is made, even when I tell it to.
Anyway, yea Jay put it to a T.
I am getting the block resurfaced too though.. so I wanna say probably 10 thou total. Or more.. always look at the worst possibility
- Trav
