79 KZ1000 Cam Timing HELP!!!
Re: 79 KZ1000 Cam Timing HELP!!!
18 Apr 2011 00:48 - 18 Apr 2011 00:49
#445245
six862m6 wrote: ...Anyone have some small shims (2.25 or smaller) they want to sell? so I can get a good base point and do the math. Also.... need some parts for some flat slides (Mikuni RS34s) looking for a bowl and 4 new float needles and seats....
If not already done, would check out KZr's Classifieds categories, and possibly post in Wanted. :)
Last edit: 18 Apr 2011 00:49 by Patton.
  • richrand
  • richrand's Avatar
13 Jun 2012 22:42
#528987
Top. Holy sh*t. The big line across the exhaust cam is not the reference mark? my god. so the "mark" is the point of the isosceles triangle made by the bolt pattern? because there is no real discernible mark. hope i didn't bend all of my valves. :(
  • six862m6
  • six862m6's Avatar Topic Author
13 Jun 2012 23:05
#528990
Sorry to hear that my friend.... it sounds like you made the very same mistake I did. There is actually a very small carrot on the exhaust cam that looks just like the mark(s) on the intake cam that you are supposed to use. Its definitely not the flat lines that go all the way across. I hope you didn't bend any valve man... I wasn't so lucky though; it caused me to bend almost every valve in my head (and I only hand cranked it). :(
David
'79 1000LTD
1075 Kit
RS34s
Mild Port&Polish
Kerker Header
  • richrand
  • richrand's Avatar
14 Jun 2012 11:20
#529079
Yup. Compression = 80 on nos 1-3 and zero on no. 4. I'll take a day off to clear my head.
  • richrand
  • richrand's Avatar
14 Jun 2012 16:59
#529125
Whelp. Didn't take the day off. Pulled the head and i've got 6 of 8 valves bent. New valves are on the way.
  • Old Man Rock
  • Old Man Rock's Avatar
15 Jun 2012 00:16 - 15 Jun 2012 00:17
#529218
As others have provided... it's the > mark not the lines on the exhaust cam...
Maybe this help when ready to put back together after repair...
With 1/4 @ TDC "T Mark" as you have in the image, from the right side of the engine looking at Cams...
Both cam lobe tips should be facing in @ deck height....
Right side image is the correct alignments!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 15 Jun 2012 00:17 by Old Man Rock.
  • richrand
  • richrand's Avatar
15 Jun 2012 18:22
#529375
Thanks. That pic is super helpful.
  • Tomolu5
  • Tomolu5's Avatar
15 Jun 2012 18:41
#529386
I made the same mistake, got away without bending any valves though, suprisingly. I saw all the valves afterwards because I decided to have Larry cavanuagh do his magic on it. Happy, very happy. I'm planning to assemble it tommorow, and I'm also planning to go camera phone crazy during the assembly process. Then I will start a thread.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • Killerkz101180
  • Killerkz101180's Avatar
23 Mar 2022 23:19
#864253
Assuming i did all the steps correctly and all of that ....I have 2 questions on this topic at what point do I put the tensioner in ? it is a aftermarket APE type with the bolt and plate and is there  And is there a general rule on adjusting that tensioner ? ......
and maybe I have a 3rd question lol.  If I do all the timing and I'm going to time my Cams with a degree wheel after im finished finding lobe centers is it ok to turn motor backwards to adjust the APE cam sprockets to get them to 110° or whatever degree I'm going for ?
thanks
