- Thank you received: 133
Valve clearance: not enough? or too much?
- Topper
This is a '79 KZ750 twin with those large, hard to find, 32mm valve shims on top of the bucket. Clearance spec according to my manual is .05-.1mm.
The shims that were installed were 250s. The only smaller shims I can find are 235s (from Z1). That results in .152mm of clearance on my left cylinder and .229mm on the right.
So until I find proper shims, which is better: to run with no valve clearance or to run with too much?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Thank you received: 2236
However, I am a bit confused by the math here, or maybe I just don't understand the whole thing.
Let's say the lash is actually .035. The difference between a 250 shim and a 235 shim is .015, isn't it? If we add .015 and .035, we get .050, not .152 or certainly not .229. If the lash is zero or less, the final lash with the 235 shim will be .015 or less.
Or maybe I'm just a mo-ron :silly:
- Topper
2.35(shim) + .229(clearance) = 2.579
So with the 250 I should have .079 which would be within spec.
Time to get the feeler gauges out again and double check.
1979 KZ750 Twin
- Topper
They told me its a 250, but now I think its more like a slightly worn 260.
I swapped some shims around and now all but one is within spec. It's the exhaust valve on the left cylinder.
It has a 235 in it (at least so the stamp says) and .15mm clearance (spec is .05-.1). I have another 250 which takes the clearance down to 0. Finally something makes sense.
I need a 240 but can't seem to find one. So my original question still stands, though with slightly different details.
Which would be better, a valve with no clearance or a valve with a little too much?
Maybe I should say which would be less bad?
1979 KZ750 Twin
- Thank you received: 2098
...swapped some shims around and now all but one is within spec. It's the exhaust valve on the left cylinder.
It has .15mm clearance (spec is .05-.1). I have another 250 which takes the clearance down to 0... eed a 240 but can't seem to find one. So my original question still stands, though with slightly different details.
Which would be better, a valve with no clearance or a valve with a little too much?....
Imo the 0.15 exh valve clearance will be okay to run.
- Topper
1979 KZ750 Twin
- stonemaster
- Visitor
- bountyhunter
- Thank you received: 337
Too much is better. Insufficient clearance = burned valve seat and ruined head.Which would be better, a valve with no clearance or a valve with a little too much?
Original spec on mine was .05mm to 0.1mm (which is .002" to .004") but I run .003" to .005". I also think .0.15mm (.006") is OK for an exhaust valve.
- bountyhunter
Somebody on this forum posted that they had some 32mm shims.Thanks Patton! Time to put the valve cover back on and keep my eye out for some more shims.
kzrider.com/index.php?option=com_marketp...&adid=4375&Itemid=46
- Topper
I've emailed him three times with no response.
1979 KZ750 Twin
- bountyhunter
- Topper
1979 KZ750 Twin
