Helicoil or Timeinsert?
  • BSKZ650
  • BSKZ650's Avatar
Re: Helicoil or Timeinsert?
25 Feb 2011 06:09
#433294
Helicoils will work just fine.
77 ltd1000, current rider
76 kz900, just waiting
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
25 Feb 2011 07:13 - 25 Feb 2011 07:13
#433308
Use the Timecoil... I mean the Helisert... oh whatever!
Theres an actual ft/lb rating for spark plug tightness in your manual. You would be surprised to find they seal up tight if you just give it an 1/8th turn after hand tightening.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 25 Feb 2011 07:13 by TeK9iNe.
25 Feb 2011 07:58
#433320
bloglos wrote:
Holy shitballs that seems pricey.
One more reason I use a torque wrench; too bad the PO didn't understand that steel (as in bolts and spark plugs) is stronger than aluminum (as in cylinder head and engine cases). Before deciding on which fix, you may want to check out the other threads in the engine that the PO may have damaged. If there are more it may be cheaper to buy the full kit rather than have a shop fix the problems, but if it's only 1 hole a shop may save you $$. Ed
  • BSKZ650
  • BSKZ650's Avatar
25 Feb 2011 11:16
#433357
most of the time when spark plug threads are damamged, its one of 2 things,, 1 cross thread the plug or 2 no anti sieze on the threads, when its removed the threads "gauld" together and the alum is pulled out.
