Starter clutch issues to check?
- calebstrawn
Re: Starter clutch issues to check?
07 May 2014 11:07
Hi all,
I've had starter issues: the typical can of rocks noise, and the starter only engaging some of the time, etc. so I was convinced it was my starter clutch. Now that I've pulled the clutch and inspected it, I don't see any major issues or differences to the brand new one I bought. Can a starter clutch be bad without having any physical damage visible? I'm going to put the new one in for good measure, but I'm concerned that I may not solve the issue, and would have to crack open the bottom end again to find the real problem. I'd rather get it right the first time, and get riding... Any thoughts? Thanks.
85 ZN700 LTD Shaft
- KZQ
- Administrator
07 May 2014 11:25
Hi Caleb,
Look very closely at the springs and cups that push the rollers against the boss. Chances are that one or more is worn/chipped/cracked or crushed. Generally replacing the rollers, springs and cups will get the clutch working again, although to work as good as new the boss/ sprocket needs to be replaced also.
Good Luck
Bill
Good Luck
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
07 May 2014 12:08
Take a look at the starter clutch diagram below. Are there any pieces in that diagram that you do NOT plan to replace? Ed
Attachment 00011_2014-05-07.jpg not found
- JimB
07 May 2014 12:58
Look at the spring lengths. Most likely if there is no noticable physical damage the springs are loose and not applying the same force to engage the clutch. When I replaced mine they were a little bit shorter but compressed easier.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- calebstrawn
07 May 2014 20:59
Yeah, I pulled the springs out of the old clutch and they seem weaker than the new ones. Hopefully this does the trick. I did notice a bit of slack or wiggle between the inner and outer coupling where the main chain drives the secondary shaft. Is it normal to have a little play (2mm of travel) here? Or should I go ahead and order new rubber dampers? I appreciate the quick responses. I'm pretty new to working on bikes, thanks for your patience.
85 ZN700 LTD Shaft
08 May 2014 05:44
- calebstrawn
08 May 2014 08:27
Thanks, Ed. I've replaced 13193, I am not replacing 12406, the teeth show no signs of wear, it is straight and solid.
85 ZN700 LTD Shaft
08 May 2014 08:48
If is was mine and I was going through the trouble of replacing the other pieces I would also replace 12406. I suggest you at least check it VERY carefully before deciding not to replace it. It isn't the teeth that are a problem The problem is the race that the rollers engage. Take a look at the images below and notice the wear on a used part compared to the surface on a new old stock part. Those ridges on the surface of the used part cause the starter clutch to slip even with new rollers, so check to see if yours looks like the used part or the new part. Ed
Attachment 00000a_2014-05-08.jpg not found
Attachment 00000b.jpg not found
- calebstrawn
08 May 2014 13:07
Ed, Thanks for the pics. This helps me to understand so much better. Yes, mine is worn like the one in the picture and to my budget's demise, I've ordered the starter sprocket as well. As much as I love working on this thing, I'd rather be riding it than fixing the same thing twice. After this, it's on to the carburetor issues.
85 ZN700 LTD Shaft
