- Thank you received: 104
The Right Cams...
- larrycavan
- Visitor
They can and will spit a shim, it's just a matter of when. I'm thinking this went at a gear change at redline in 4th gear. People watching said at gear change it went stupid all over the track. Guy spent a long time in the hospital. I'm not saying it didn't spit during the wreck, rev limiter was set at 10,000, but something caused the bike to go nuts and I'm thinking it may have been oil from the hole.
Not trying to sway anyone away from what the manufacture says but I'm not going to chance it.
What cams?
- PLUMMEN
anybody who wants to run a motor with rev limiter set at 10g needs to spend the money on whatever it takes to hold it together.They can and will spit a shim, it's just a matter of when. I'm thinking this went at a gear change at redline in 4th gear. People watching said at gear change it went stupid all over the track. Guy spent a long time in the hospital. I'm not saying it didn't spit during the wreck, rev limiter was set at 10,000, but something caused the bike to go nuts and I'm thinking it may have been oil from the hole.
any design has its limitations,if you push it beyond those limits you have no bitch as far as im concerned.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- PLUMMEN
- les holt
- Thank you received: 288
Not trying to ruffle feathers, just pointing out it can happen and if a person can afford it, go shim under bucket. Just added insurance.
- larrycavan
- Visitor
Ported head, stainless valves, ape springs. Pretty good build but I can't say why it happened. Thats the way it was when I bought it. The guy that had it won't ride again. Can't say I blame him, been a couple yrs and he still limps. This isn't the first time I've seen it happen and I believe that for whatever reason I wouldn't take that chance again. It has never happened to me personally so I consider myself lucky, I do push these things hard.
Andrews used to call for SOB for 8x and SOT for 3x grinds. The truth of the matter is you're more likely to spit a shim with a 3x than an 8x.
That out of the way, is there a grind number on that exhaust cam?
- les holt
- PLUMMEN
youll can probably find em cheaper than that even,just get the right retainers to go with.
- larrycavan
- Visitor
The owner is cheap and won't replace either. Bye - Bye... have a nice day :laugh:
- PLUMMEN
im talking a budget weekend warrior! :laugh:
- les holt
- PLUMMEN
if youre just turning high rpms occasionally without a huge amount of lift with cams requiring bigblock chevelle coil springs to keep valves from bouncing id say youll be fine.
im guessing the 650 buckets are made from same material as 900-1000 style
