retarding exhaust
29 Dec 2010 22:15 - 29 Dec 2010 22:43 #419248 by nads.com
retarding exhaust was created by nads.com
I've read where four wheeler owners retard the exhaust timing as a mod to extend the power toward mid and top. If you make clearance at the piston to allow for collision, would there be an extended power band? If it's retarded too much would blow down occur so late the exhuast pressure would hold up the rising piston? How bout 112in. 102ex ?? what would it do? I'm looking for an extended high end, I just need to shift the peak up a little more and have good charge right to it. I'm ready to toy with the exhaust but don't know where to go.. Just don't want to make 5 changes when it could be one or two. It's like asking about a rare coin that doesn't exist :blink: :woohoo: found it!! Remember, if know one knows, I'll have to find out. The quest for power. Endless strides through the desert, sun beating down on your back, sweat rolling into your eyes, walking through the valley of one heck of a party fear creeps into your bones, where is your bike? Small voice inside says drink the puke in the helmet and go charge cactuses. :woohoo:
Last edit: 29 Dec 2010 22:43 by nads.com.
30 Dec 2010 06:57 #419278 by Old Man Rock
Replied by Old Man Rock on topic retarding exhaust
"Small voice inside says drink the puke in the helmet and go charge cactuses." :laugh: :laugh: :laugh: :laugh:
This made me laugh.... Not sure WTF "cactuses" are :blink: but laughed just the same...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • andy9802gt
  • If it tastes that good, eat it yourself.
30 Dec 2010 07:02 #419282 by andy9802gt
Replied by andy9802gt on topic retarding exhaust
I think he meant "cactii" . Drink the kool-aid, put on your Nike airs, and go lay down in bed until the mothership gets here.:P
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
30 Dec 2010 11:53 - 30 Dec 2010 11:54 #419359 by bountyhunter
Replied by bountyhunter on topic retarding exhaust
Not on my 750 twin. The horsepower peaks at about 7000 and redline is about 7500 so it already peaks right at the top. Bike makers are pretty good at squeezing all the power out of these engines.
Last edit: 30 Dec 2010 11:54 by bountyhunter.
  • TeK9iNe
  • What did you do!?!
30 Dec 2010 15:48 - 30 Dec 2010 15:50 #419397 by TeK9iNe
Replied by TeK9iNe on topic retarding exhaust
VARYING LOBE SEPARATION ANGLE
Tighten***********************************Widen
Moves Torque to Lower RPM ***********Raise Torque to Higher RPM
Increases Maximum Torque ************Reduces Maximum Torque
Narrow Powerband *********************Broadens Power Band
Builds Higher Cylinder Pressure *******Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock *****Decrease Chance of Engine Knock
Increase Cranking Compression ******Decrease Cranking Compression
Increase Effective Compression *******Decrease Effective Compression
Idle Vacuum is Reduced ***************Idle Vacuum is Increased
Idle Quality Suffers **********************Idle Quality Improves
Open Valve-Overlap Increases *********Open Valve-Overlap Decreases
Closed Valve-Overlap Increases *******Closed Valve-Overlap Decreases
Natural EGR Effect Increases ***********Natural EGR Effect is Reduced
Decreases Piston-to-Valve Clearance **Increases Piston-to-Valve Clearance
Above 114 Deg. = Extremely Wide
114-112 Deg. = Wide
112-110 Deg. = Moderately Wide
110-108 Deg. = Moderate
108-106 Deg. = Moderately Tight
106-104 Deg. = Tight
Below 104 Deg. = Extremely Tight
ADVANCING / RETARDING CAM TIMING
ADVANCING **********************************RETARDING
Begins Intake Event Sooner *****************Delays Intake Event Closes Intake
Open Intake Valve Sooner *******************Keeps Intake Valve Open Later
Builds More Low-End Torque ****************Builds More High-End Power
Decrease Piston-Intake Valve Clearance ****Increase Piston-Intake Valve Clearance
Increase Piston-Exhaust Valve Clearance ***Decrease Piston-Exhaust Valve Clearance
Changing one and not the other causes varying degrees of things from both lists!!! :laugh: :laugh: :laugh:
B) Best of luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Dec 2010 15:50 by TeK9iNe.
  • gearheadmm
  • MUCH MORE BOOST..........I mean BRAVO
30 Dec 2010 19:05 #419422 by gearheadmm
Replied by gearheadmm on topic retarding exhaust
NAILED IT! Catii take cover.;)
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
  • larrycavan
  • Visitor
31 Dec 2010 07:35 #419472 by larrycavan
Replied by larrycavan on topic retarding exhaust
Throw in some drop in cams on 116 centers and watch what happens at 4k
  • TeK9iNe
31 Dec 2010 10:22 #419491 by TeK9iNe
Turn your 4 stroke into a 2 stroke !?! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • trianglelaguna
31 Dec 2010 10:54 #419501 by trianglelaguna
Replied by trianglelaguna on topic retarding exhaust
at midnight we cut our balls off and then meet up behind the comet...i have my roll of dimes
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
31 Dec 2010 15:53 #419521 by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
31 Dec 2010 17:38 #419534 by keith1
Replied by keith1 on topic retarding exhaust
got anything of value you want to leave me? besides the taurus and the projects and the errant bag of shroom' tips under the couch cushions?.....:laugh: and no, i dont want your scrotum contents........:(
02 Jan 2011 00:27 #419699 by nads.com
Replied by nads.com on topic retarding exhaust
What is this 4grand happening so spoke of o riddler?
