MTC pistons?
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- APE Jay
- Banned
- Thank you received: 58
- kz1k
1978 KZ1000A2
- davel
MTC makes a good piston. Cylinder pressure may be a little high if you use them with stock cams. Use the fiber head gasket.
Jay, Wouldn't the copper head gasket provide better heat dissipation and allow you to run higher cylinder pressure on pump gas?
- steell
How do you get the copper head gasket to seal without o-ringing the head or block?
- davel
These guys www.headgasket.com/ make a SS oring that's 0.004 thick and meant to work with a copper head gasket to seal it to the block. No machining necessary.How do you get the copper head gasket to seal without o-ringing the head or block?
Copper head gasket faqs here:
www.headgasket.com/faq.html
instruction for installing SS oring here:
www.headgasket.com/images/ring%20installation.pdf
Not sure if it works but I might try it this winter on my 1075.
- APE Jay
- Banned
Copper will seal very high cylinder pressure, much higher than you would run on the street. However, they are oil leakers, so they are used as a last resort with high compression drag motors.
- keith1
- Thank you received: 2
i am trying to decide if i should just buck up and bore my 903 up to a 1015. i was reading it really adds a lot of low end torque and throttle response even with stock cams. whats the story with these MTC pistons? many people running them? and whats the difference in the copper of fiber head gaskets?
i m sure im the last guy you want to hear from...that being said:
they are good pistons.
get a one pc cometic or wiseco fiber gasket and seal the o-ring groove...dont go bannanas.....just a tad above flush....
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- toad
- Thank you received: 7
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- DoubleDub
- Visitor
Last time I checked MTC wasn't making KZ pistons in the smaller sizes, check before making plans. Wiescos hold up fine. I've run a 250hp turbo on a set of 1075 9to1 without problems. Ditch the clips and run buttons, .020" endplay. Copper head gaskets leak oil, you ain't gonna stop it even with external oil lines. At best they last about 2 seasons on the street.
I noticed APE has the Wiseco *AND* MTC 1015cc kit listed on their page still. They might have some on the shelf... The MTC page does not list the 1015cc anymore.
www.kzzone.com/pistons.html
