- Thank you received: 20
cylinder block mill
- nads.com
- DoubleDub
- Visitor
Decking the head will increase compression by reducing the space above the piston, reduce piston to valve clearances, possibly affect cam timing. Not sure what the accepted level of decking is. Someone more experienced will have to answer that.
What cams are you running? I would think cam lift would affect the amount that can be decked.
- nads.com
What is the secret here? Excuse me if this has been hashed. I don't remember anything like answers or useful info on the topic at all. Just a bunch of "you gotta calc this and watch that and .... I wanna know what will make this motor quick. There is no magic. Just facts and people have been holding back. Someone needs to break into the kz vault and grab me the s file. And dont'
bring any of those goons
Now watch, here comes the valve clearance goons again. Eternally warning you of valve to valve and piston to valve clearance, shaking their fingers into your face. You just want to bite the finger off, like that? We also don't need the combustion chamber gang. The ones who believe it's inevitable like California sinking , that the piston will "eventually hit head" 100rev's, 100yrs? Just that at some point, bam. No way to stop it. So we know whose invited to the party people with something to say.
- testarossa
- Thank you received: 82
www.gasgasrider.org/html/measuring_squish.html
www.motorcycle.com/how-to/wrenching-with...ion-3420.html?page=2
Just use these techniques to measure your current squish clearance, and then adjust by milling the head or block. Then you need to recheck piston to valve clearance and make sure that you have 0.080" on the intake valve and 0.100" on the exhaust valve. This might necessitate milling the pistons to achieve the desired clearance.
Also note that your camshaft timing will be affected by cutting the head or block.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- steell
The ability to build a motor that does that is the difference between a real engine builder and an amateur.
What people normally do is calculate the specs to allow the piston to lightly kiss the head, then allow 0.035" to 0.040" for safety.
No guts, no glory
- nads.com
- bountyhunter
- Thank you received: 337
I remember I researched flow techniques a long time ago and was amazed at how complicated it is. Also, bigger is not always better. The whole system has to be tuned to sing together to get best flow. There was a case shown where somebdoy increased valve size in an attempt to make the engine "breathe better" and they actually reduced the power because it screwed up the flow match. It seems like it is a black art and some people know how to do it but most people don't.Cuz I really want this bike to rip/fly. I need the head to flow some air regardless of valve size!
- kawsakiman
- Thank you received: 6
get yourself a nice box and pack it up real nice and send it to larry or ape.
some things are just best left to the experts.
- keith1
x2.....kinda like shopping in new york...if ya gotta ask how much....get to stepping.......if you havent a clue...send it out......
- nads.com
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- APE Jay
- Banned
- Thank you received: 58
