missing 1985 zn1100
30 Nov 2010 12:15 #414837 by schwartz
missing 1985 zn1100 was created by schwartz
zn1100 engine missing
Took bike to dealership to check engine misfire under load! mechanic syncronized carbs and raised needle to richen mid range and said it was good! I drove home got 2 miles from dealer and started missing so went home. Took back up to mechanic and now he did compression check, it was good, took carbs apart found some rust particles in carb bowl and cleaned all up put inline fuel filter in and assembled back together and said it was good to go. Called me and said it was ready for pickup so i told him be there tommorow to pick up.The next morning i was going to get it and phone rang, mechanic took bike for a spin that morning and to his surprise it started missing when he drove it. When he drove it one direction bike started to miss and when he turned around and went opposite direction it didnt miss so now he thinks its the wind causing a vacuun leak stopping fuel to carb or carbs.its still at shop gong on 2 months. Ive had carbs cleaned, carbs synchronized, replace all intake rubber boots, new needle and seats in carbs, new spark plugs, gas tank drained ,cleaned, inline fuel filter installed. Can anyone help me!!!!! thanks scott
30 Nov 2010 13:00 #414843 by keith1
Replied by keith1 on topic missing 1985 zn1100
vent clear for the fuel tank cap?
30 Nov 2010 13:09 #414844 by schwartz
Replied by schwartz on topic missing 1985 zn1100
I'm not sure on that. Does this model have a vent built in fuel cap?
thanks scott
30 Nov 2010 16:23 #414862 by kawsakiman
Replied by kawsakiman on topic missing 1985 zn1100
pods or airbox?
either case start looking at the ignition side.
30 Nov 2010 17:51 - 30 Nov 2010 17:55 #414869 by schwartz
Everything on the bike is stock. I sure would think the mechanic working on bike would check them out but not sure at this point. Bike has 17,000 miles on it. I haven't heard anything from the shop in 2 weeks. Shop started working on bike Oct.1,2010. Anymore suggestions would be greatly appreciated. thanks scott
Last edit: 30 Nov 2010 17:55 by schwartz.
  • andy9802gt
  • If it tastes that good, eat it yourself.
30 Nov 2010 18:00 #414873 by andy9802gt
Replied by andy9802gt on topic missing 1985 zn1100
Sounds more like the coil or ignition breaking up to me if it's only happening every couple rides like you stated Electronics are weird like that.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
30 Nov 2010 18:23 - 30 Nov 2010 18:24 #414879 by schwartz
Is there a way that the electrical parts you are talking about can be checked to see if they are the issue. At least then that could be one less thing or things it could be causing the problem. thanks again Scott
Last edit: 30 Nov 2010 18:24 by schwartz.
30 Nov 2010 20:15 #414905 by MFolks
Replied by MFolks on topic missing 1985 zn1100
If it were me, I'd get some "De-oxit" electrical contact cleaner/preservative and clean all ignition related conectors. This might take a day to throughly do all the connections(one at a time to avoid mixing up circuits).
www.deoxit.com is their website, and it's available at Radio Shack Stores in the U.S. and other electronic supply places. It's a pricey item($15 for a two pack) but good stuff.
I use this cleaner on my bike,home entertainment center cables, and cordless phone charging cradles.
  • clutch
  • I wish I had a tad more patience to do it better!
30 Nov 2010 20:22 #414906 by clutch
Replied by clutch on topic missing 1985 zn1100
Sounds like a loose or broken wire in the ignition system. Turning loosens/reconnects it...I would look at the wiring and connectors first.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • roccbottom
  • 1984 gpz1100, 1995 kz1000p
30 Nov 2010 22:03 #414911 by roccbottom
Replied by roccbottom on topic missing 1985 zn1100
Sounds like a play back of my GPz 750. Shop situation and all. If your the least bit mechanically inclined. retrieve your bike bro. because its just sitting there. It could sit at home with you. for no charge. My problem was an intermittent short in my starting system. went through my bike,cleaned and resoldered some connections. ran beautifully afterwards. Post your progress someone here has been through it believe me..Good luck
01 Dec 2010 12:41 #414946 by Patton
Replied by Patton on topic missing 1985 zn1100
In addition to all the above, would assure:
Functioning automatic advancer (viewed under timing light);
Fat blue spark at plug tips;
Good battery, fully charged;
Clean snug battery terminals connections, and integrity of connection where negative battery cable attaches to rear of engine;
Measured voltage being received at ignition coil primary terminals;
Ohm check primary windings and secondary loop (Kawasaki ignition coil electrotester would be even better);
Spray water mist over coils and plug wires in dark garage with engine running (look for sparks = leaking voltage);
Valve clearances to specs;
Check float bowl fuel levels using clear tube method;
Petcock screens should be clean and clear;
Fuel should freely flow from petcock;
Assure integrity of vacuum line from carb to petcock (snug fit with no leaks or cracks).
Good Fortune! :)
01 Dec 2010 15:03 #414959 by schwartz
Thanks for all of the advice given. I'm going to call shop tonite and see where that at with bike. Then i will determine whether i go pick it up and pay bill and start trouble shooting all the options i have been given from you guy's. Again i really appreciate all of your help in trying to get my bike back up and road ready! thanks Scott
