1978 KZ1000 Top Speed
- lemo32
- The Price of Cool aint cheap
Re: 1978 KZ1000 Top Speed
28 Nov 2010 18:03
This could be a blessing in disguise, not trying to be a smart a"" but riding a 32 yr old machine over 120mph could be hazardous to ones health, I heard the old timers claim these bikes had high speed wobbles, probably catch hell for this post but if i wanted to go over 120 mph it wouldnt be on a kz, without serious mods!
1979 kz 1000 06 katana 750
- keith1
28 Nov 2010 18:04
TerryK wrote:
keith1 wrote:Mykuh wrote:thanks for the input guys ! 1st off,the bike as far as I can tell is bone stock except the kerker 4-into-1, the free flow air for the carbs. I am not a mechanic but love to ride this thing and the guy I took it to is a motorcycle mechanic that "claims" he used to work on these bikes new.
He said I needed the high octane to help the bike run better.
The speedo and tach look stock to me, so not sure if both are reading correctly or not, except I did go through a traffic radar "box" that let you know your speed and said I was doing 23 and the speedo was at 25. Might get worse the faster the bike goes?
go one down in the front and i bet it will....
I am glad I found this place with such a vast knowledge base and maybe I can learn to get the bike where it needs to be and KNOW it is right.
Thanks Again !
just my .02, but that bike should easily rev to 9k....probably needs re-jetting......pods and a pipe require at least 2 up on the pilots and 3 on the mains if i remember correctly......then theres the baffle in the pipe...a lot of variables...if that thing wont pull cleanly to 9k, dont push it untill re-jetting...you are way lean and you will eventually grenade a piston....again, there are a lot of variables here....stock ignition/aftermarket, plugs good, carbs in a good state of tune, good battery,valves adjusted correctly, etc.......
I believe he's wanting it to rev to 9k in top gear, but many of these old bikes wont pull red line in top gear.
- keith1
28 Nov 2010 18:06
keith1 wrote:
post got flubbed......if the bike is in a good state of tune, go one down on the front sprocket, she'll go to redline......
TerryK wrote:keith1 wrote:Mykuh wrote:thanks for the input guys ! 1st off,the bike as far as I can tell is bone stock except the kerker 4-into-1, the free flow air for the carbs. I am not a mechanic but love to ride this thing and the guy I took it to is a motorcycle mechanic that "claims" he used to work on these bikes new.
Thanks Again !
- Ktm181
- Man made it, so Man can fix it
28 Nov 2010 18:18
+1 on Keith's idea. My stock 900 had a 4 into 1 and pods
fitted and dropped almost 6-7mph top speed, 120 mains got it back to 120 plus with 15/35 gearing, speedo error not accounted for! Still it pulled 8000rpm in top so quite ok for a stocker with minor mods. It's now in the process of getting the "LarryC head treatment", 1075, 29 smootbores, Z1 cam etc, so should get there a lot faster with same top speed at those revs!
Cheers from Oz,
Kt
Cheers from Oz,
Kt
- keith1
28 Nov 2010 18:50
Ktm181 wrote:
you will have a rocket when set up right.....pork it in first at 3k and let us know when it lands....:laugh:
Cheers from Oz,
Kt
- Nelson
28 Nov 2010 21:23
hmmm.. the phrase I've heard is "That bike is a 120 mph engine in a 80mph frame" :lol:
pray for smooth roads!
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- z1kzonly
28 Nov 2010 22:40
TWIST IT FOR A 1/4 MILE THEN SHUT IT DOWN!
I AM TOO OLD TO DRIVE ONE ON THE HIGHWAY OVER 75 MPH
- Kawickrice
29 Nov 2010 05:36
High speed wobbles at 120+ on a KZ is a pucker factor of 9.9 Ask me how I know
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- hocbj23
29 Nov 2010 06:15
wobbles at any speed over 80 is a 9.9 pucker factor.Ask me how iknow.lol.bj
- Mykuh
29 Nov 2010 10:18
good input guys thanks ! as far as a wobble, the bike doesnt wobble when I max out at what ever speed it is running.She is very smooth.
1978 KZ1000A
- TerryK
29 Nov 2010 15:30
lol, yup. I didn't want to scare the guy but yes, these old bikes WILL wobble. WAY too much frame, fork and swingarm flex stock. I gusseted my frame, adapted a GSXR swingarm and added a steering damper after a couple of "interesting" incidents, the worst of which involved myself and a couple of friends doing some spirited riding in some twisties. I was following one guy through an 80mph corner and his bike stated to weave to the point I could actually see the swingarm flexing! Seriously. The bike was rotating one way while the rear wheel was going the other.
Scariest shit I've ever seen! :ohmy:
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Nebr_Rex
29 Nov 2010 18:20
hocbj23 wrote:
A wobble at 50 mph can get ya some extra plates and screw installed also.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
