cam noise
13 Nov 2010 07:23 #412503 by bls5050
cam noise was created by bls5050
Hello, folks. I'm trying to diagnose a potential problem with my motor, and the SEARCH function has been helpful, but I haven't found anything that directly matches my symptoms.
The bike is a 1980 KZ1000ST (the same bike in the KZ1000ST Resuscitation thread in the Projects Forum). The bike is stock as a rock, with the exception of a K&N filter in the stock airbox.
The bike fires up and runs fine. Pulls like a team of mules. Spark plugs come out dry with a light grey/tan coating. The problem is that at idle, you can hear a "whirring" sound coming from the valve covers. Using a "screwdriver stethascope(SP?)", the sound in even between the front and rear cams, and louder on the right side. The cam chain appears normal. Most of the info I found using the search function referred to chain slap at idle from the cam chain. This is not a "rattle". This is a very distinct "whirring".
I switched to Shell Rotella oil, and this got rid of all other oddness from the motor, but the cam noise is still there, maybe it's more pronounced because all the other noises are gone? This morning I pulled the valve cover to check top-end lubrication and valve clearances. Valves are well within specs. One thing that I noticed when I pulled the valve covers was that oil was pooled up on exhaust valves #1 and #4 to the gasket surface. But the cams appear to be getting plenty of oil otherwise.
My question is, is this normal, or is this a problem? Remember this: Your only paranoid if you're wrong!
1980 KZ1000st
13 Nov 2010 07:59 - 13 Nov 2010 08:02 #412507 by Patton
Replied by Patton on topic cam noise
bls5050 wrote:
...1980 KZ1000ST..stock...K&N filter in the stock airbox...runs fine... at idle, you can hear a "whirring" sound coming from the valve covers...cam chain appears normal...not a "rattle"...very distinct "whirring".
...is this normal, or is this a problem?...
Am thinking cam chain sound has generally been more audible on the bicycle style cam chain as opposed to the later Hy-Vo design, even off the show room floor.
Often, a good close carb sync will noticeably reduce cam chain noise at idle rpm.
But the sync is perhaps more curative to rattle than whirring.
Good Fortune! :)
Last edit: 13 Nov 2010 08:02 by Patton.
13 Nov 2010 08:13 #412511 by bls5050
Replied by bls5050 on topic cam noise
The two things that quieted the engine down the most were a carb synch with a Morgan Carbtune and switching to Rotella oil. I had originally synched the carbs with a cheappo guage settup that did not have numbers on the face, only hash marks and it didn't make much difference. I redid it when I recieved the Morgan setup, and the engine smoothed right out and produced noticably more power down low.
In a related matter, I just finished ripping the oil filter that just came out apart to read the filtering media. There was a slight amount of magnetic material, I assume from the rings reseating after sitting for more than fifteen years, but nothing out of the ordinary, so the motor isn't "making metal".
1980 KZ1000st
  • larrycavan
  • Visitor
13 Nov 2010 19:31 #412597 by larrycavan
Replied by larrycavan on topic cam noise
Did you closely inspect the top idler sprocket? I've seen a lot of bad ones on the KZ motors that come in. One was dam near ready to fall apart...
14 Nov 2010 09:12 #412671 by bls5050
I took the valve cover off again and looked at the top idler sprocket. It seems like it has alot of play. It can move side-to-side maybe 1/8 inch, but it can move slightly up and down and back and forth on it's shaft, also. The FSM and the Clymers manual dont list wear specs on this part, so is this normal, or is this a possible culprit?
1980 KZ1000st
14 Nov 2010 10:18 - 14 Nov 2010 10:19 #412687 by Patton
Perhaps sprocket needle bearing is shot, which might also explain the magnetic material found in oil filter.
Good Fortune! :)
Last edit: 14 Nov 2010 10:19 by Patton.
14 Nov 2010 11:21 #412696 by Kapahulu
Replied by Kapahulu on topic cam noise
At what mileage should the idler sprocket be changed?
2strokeworld.com
14 Nov 2010 11:55 #412701 by Patton
As the idler sprockets aren't part of scheduled maintenance, they would be changed when worn or damaged (same as cam chain). Permissible cam chain stretch is addressed in the FSM.
As with most engine components, conscientious periodic maintenance should enhance longevity.
Good Fortune! :)
14 Nov 2010 18:40 #412815 by TerryK
Replied by TerryK on topic cam noise
If the sprocket has radial play (up and down) change it immediately. The rubber that the bearing is suspended in wears out more often than the bearing. The rubber gets very hard and brittle from exposure to heats and caustic chemicals in used oil.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • larrycavan
  • Visitor
15 Nov 2010 04:48 #412849 by larrycavan
I would suggest a new Liska with new pillow blocks :)
15 Nov 2010 05:12 - 15 Nov 2010 05:14 #412853 by Patton
Last edit: 15 Nov 2010 05:14 by Patton.
16 Nov 2010 04:25 #412980 by bls5050
Thanks for the responses. You've pretty much sold me on a new Liska unit and aluminum pillow blocks, but this brings up a question: Can the Liska idler sprocket www.z1enterprises.com/detail.aspx?ID=2177 be retrofitted to my existing assembly? Or is that part just a replacement sprocket for this: www.z1enterprises.com/detail.aspx?ID=2178
I looked at the idler assembly, and it was not immediately apparent as to how to get the idler sprocket off of it's shaft. Maybe a press-in part?
1980 KZ1000st
