1983 GPZ 750 FRESH REBUILD 110PSI COMPRESSION????
- skemp101
Re: 1983 GPZ 750 FRESH REBUILD 110PSI COMPRESSION????
12 Nov 2010 11:12
I SET THE CRANK TO THE T MARK AT 1& 4 TDC. INSTALLED THE EXHAUST CAM TO "Z7XE" OR SOMETHING FLUSH TO CYLINDER TOP FRONT. INTAKE CAM "IN" MARK TO REAR BETWEEN 45-46 TOOTH. BOTH CAM NOTCHES ARE FACING IN. IT IS SHIMMED PROPERLY WITH IN A RANGE 0F .003-.007. I AM TOTALLY BAFFLED WHY THE COMPRESSION IS SO LOW. THE CYLINDERS ARE HONED FOR RING SEATING, END GAPS CORRECT. CYLINDER TO BORE CLEARANCE OK AS WELL.:S BEAUTIFUL CLASSIC ORIGINAL OWNER.
SHOULD I JUST CRUSH IT OR WHAT. THIS IS THE FULL GO THROUGH AGAIN.
WILL GETTING IT ON THE ROAD AND BREAKING IT IN BRING UP COMPRESSION?
IT IS RUNNING OK, JUST TRYING TO SET THE CARBS NOW AND I HAVE A FLOAT LEAD AT #1 CARB. MIKUNI 34'S ANY RECCOMMEND FOR FLOAT GASKETS? THEY SEEM HARD TO FIND.
THANKS
THANKS
- Becker
- The Doctor Will Rise Again
12 Nov 2010 12:16
No offense skemp but the all caps thing is annoying. When I'm reading it all I can think of is you shouting like Gilbert Gottfried as if we are at a club or concert or standing next to a jackhammer.
As far as compression goes it should continue to get batter as it gets broken in. Give it 200-500 miles and try it then.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- blipco
- 2002 KZ1000P
12 Nov 2010 14:53 - 12 Nov 2010 14:55
Becker wrote:
Not to get off topic Becker, but did you have to bring up Gilbert Gottfried? I haven't given that idiot any thought in years and now this.
OK, maybe he is a little funny with the fact that all his impersonations sound like Dracula but that is all. Alrighty then, what were we talking about?
Last edit: 12 Nov 2010 14:55 by blipco.
- skemp101
12 Nov 2010 16:05
Thanks for all the help, I will get this beut on the road and stack up a few miles. Hope it will seat the rings and bring up compression.
- bountyhunter
12 Nov 2010 19:25
blipco wrote:
AFLAC!
Now you'll never get it out of your head.....:laugh:
Becker wrote:No offense skemp but the all caps thing is annoying. When I'm reading it all I can think of is you shouting like Gilbert Gottfried as if we are at a club or concert or standing next to a jackhammer.
AFLAC!
The following user(s) said Thank You: jlaudiofan
- timebomb33
12 Nov 2010 19:59
like i said get another gauge and compare the readings maybe your gauge is off.
I THINK MY POWERBAND BROKE
- Tony
Author
13 Nov 2010 09:22
timebomb33 wrote:
I second this. After completing my engine earlier this year, my compression was also around 110. Tried a different gauge and they all changed to around 165.
- dwilliams2385
- to each there own as long as u leave me alone!!!!!
13 Nov 2010 23:29
you gotta run it and seat the rings before you can do a compression check duh?
1979 kz650 c3
- Nebr_Rex
14 Nov 2010 16:24
skemp101 wrote:
Look in your manual.
The GPZ uses Z6XE timing mark which should advance the cams and increase cylinder pressure.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- skemp101
15 Nov 2010 11:57
I was totally stoked last night. It was still running like garbage backfiring and wouldn't get above 4000 rpm. Pulled the carbs again and this time sealed between the carb and head, which I dont think there was any sealer or gasket from the factory. Put it all back together and it finally idled. I bench set the sync on carbs, after it ran I put the stick on them and fine tuned #4 and it ran better.
still popping and backfire I worked on the air fuel screw, about 3 turns out on all it ran even better.
the story gets better, I said heck " maybe I can take this sucker for a ride". Its only been sitting for 5 or so years.
A little rough at first, then the power came back. rapping it up a couple of times to higher rmp and it is running like a champ!!! I got to feel a little of that new 810 displacement.
I have had this bike since Oct. 1983, bought new and am very glad to get er on the road.
thanks to everyones help, KZR is an awsome help forum and beyond..
thanks all!!!
thanks all!!!
- Becker
15 Nov 2010 12:40
Sweet. Who bored it for you?? What exhaust and filters are you using and how many jet sizes (if any did you have to change with just the 810 kit??
Oh, and do you have any pictures??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Meat-head
14 Jun 2019 06:40dwilliams2385 wrote: you gotta run it and seat the rings before you can do a compression check duh?
This.
