79 kz1000 st no compression on all 4 cylinders
- morhaven
- morhaven
Re: 79 kz1000 st no compression on all 4 cylinders
07 Oct 2010 11:30 - 07 Oct 2010 11:35
exhaust came left
Last edit: 07 Oct 2010 11:35 by morhaven.
- morhaven
- morhaven
- morhaven
07 Oct 2010 11:34 - 07 Oct 2010 11:34Attachments:
Last edit: 07 Oct 2010 11:34 by morhaven.
- morhaven
- morhaven
07 Oct 2010 11:39
So to me its seems the exhaust cam timing is off.
can someone advise.
also if I need to fix any guidance on what I have to do with the chain tensioner
can someone advise.
- Link14
07 Oct 2010 14:50
steell wrote:
Yep...I'm there right now. 4 bent exhaust valves and one bent inlet valve will give you 0 compression! Perfect example of what happens when you put the exhaust cam back in 180 out! :blush: New valves arrive next week.
That's the next thing you should do. My guess is bent valves.
Bent valves will cause zero compression, been there, done that.
- kz1k
- You Cant Fix Stupid!
07 Oct 2010 15:03
you ganna do the whole head, or just the bad valves? whats it ganna set ya back?
1978 KZ1000A2
- RonKZ650
07 Oct 2010 15:20
Cams are both in wrong. Many a valve bent on a KZ1000 from this mistake. Look at the manuals closely, then be SURE you are using the corect mark on the exhaust cam as a reference. No doubt they used the wrong mark, counted back 28 pins to the intake and both cams are wrong, then voila' turn the engine over and bend all the valves. This can be verified real quickly. Use feeler guages to check your valve clearances, any bent valves will have gobs of clearance.
- wargoth
07 Oct 2010 15:39
Link14 wrote:
Easy way to find if the valves are leaking is remove the plugs, screw the hose for the comp tester in to each hole one at a time, turn down air compressor regulator to 30psi and connect to tester hose (most have a standard industrial coupler) and making sure the cam is pointing away from the lifters see if air is leaking out the intake or exhaust port, or case if it is piston or ring problem
this is the fastest way to find a leak I know of
steell wrote:That's the next thing you should do. My guess is bent valves.
- kz1k
07 Oct 2010 15:40
RonKZ650 wrote:
good read.Cams are both in wrong. Many a valve bent on a KZ1000 from this mistake. Look at the manuals closely, then be SURE you are using the corect mark on the exhaust cam as a reference. No doubt they used the wrong mark, counted back 28 pins to the intake and both cams are wrong, then voila' turn the engine over and bend all the valves. This can be verified real quickly. Use feeler guages to check your valve clearances, any bent valves will have gobs of clearance.
1978 KZ1000A2
