- Thank you received: 20
12-1 If I shave the head?
- nads.com
- racer54
- Thank you received: 114
- Nebr_Rex
- Thank you received: 300
Can I just shave the head and get 12-1?
What pistons are you using?
Watch your piston to head and piston to valve clearances.
Also cam chain adjustment is to be considered.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Injected
- Thank you received: 543
forums.dragbike.com/forum_topics.asp?FID=14
That is the Kawasaki specific question area...
I think you want to ask the question not in relation to piston compression ratio but cranking compression...
There are lots of guys running 300PSI in there 1400cc drag motors using modified on board starters.
Above 250PSI it gets pretty hard to kick start...
- DoubleDub
- Visitor
- nads.com
- nads.com
- DoubleDub
- Visitor
- TeK9iNe
- What did you do!?!
- Thank you received: 28
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
I've always wondered how you do the numbers to match CFM for carbs, head, exhaust.
You calculate piston demand and start right there.
As far as how much to take off a head to obtain a particular compression ratio, the best way is to cc what you have to start with.
Too many variables come into play to throw numbers out.
Sinking valves, installing larger valves, radius cutting chamber pockets.....add chamber volume.
As far as going by cranking pressure, that's not accurate at all. Different cams, different intake closing values will change cylinder pressure.
Your current piston to valve clearance at the closest point with your cams at your cam timing has to be taken into consideration.
It's not just a matter of saying oh yea...scratch .040" of the deck and you're good to go :silly:
There at lots of online calculators to help you out. Got to Wallace Racing, he's got lots of helpful online calculators.
- Injected
What I was trying to get at is that compression ratio numbers are only useful in pertaining to the octane rating of the fuel to be used and not as an actual performance indicator... you can have a 15:1 piston with low cylinder pressure.
I should have also noted that cranking compression numbers can be used as a performance indicator but can also be greatly effected by valve overlap... I alter my cam timing to achieve maximum cylinder pressures and maximum piston to valve in drag motors.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
(For 4032 material only) Piston dome cc's to gram conversion:
1cc (volume) = 2.8 grams (weight)
This is a good way to remove excess dome without having to re-cc piston: Mill a small amount and re-weight piston until total reduction is reached.
Example: A piston has 12.5cc effective dome volume. The desired effective dome volume is 10.5cc.
To remove 2.0cc, cut 5.6 grams (2 X 2. from the piston dome.
