- Thank you received: 1
can anyone identify these pistons
- kenty
- kenty
- kenty
- kenty
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kenty
i stripped the head off and all 4 pistons had oil on the tops , id done a comp test before i fired it up and it had good readings on all 4.
i took the oil rings off and measured them against the old set , the new ones had a different radial size and were slightly thinner , i never measured them before i built it up as i've never had any prob with oil rings before. :blink: you live and you learn i suppose .
anyway , no one can find me any rings unless i can identify the pistons , my only choice seems to be , have a set made , i would reuse the originals but it seems i threw two away when i cleaned up so im up the creek without a paddle .
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
- kenty
sizes are
piston groove height 2.5 mm
piston groove depth 3.57 mm
kev
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Kidkawie
- I bleed premix
- Thank you received: 245
inside the crown has been machined away
I think that's from balancing.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
