Stainless steel bolts - bad for aluminum?
- VenturaRider
Re: Stainless steel bolts - bad for aluminum?
22 Mar 2012 02:33
A noted Marine boat builder and Cummins dealer who refitted and repowered a friends 32' aluminum boat recommended using RectorSeal for stainless fasteners in contact with the salt water elements and aluminum. I must say it has worked well and will continue to use it.
www.rectorseal.com/RectorSeal-T-Plus-2.php
Box stock 75 Z1900
74 Z1900
Ventura Ca.
74 Z1900
Ventura Ca.
- 750steve
22 Mar 2012 18:50
Unless left for years (like 20) i believe stainless will be ok with aluminium. However, if you try to spin SS out of Alu quickly the heat buildup can make them bind.
Use copper nuts for holding your exhaust on & you wont have a problem.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Jeff.Saunders
22 Mar 2012 20:48
Studs are manufactured with a larger diameter on the installed end versus the end the nut goes on. This is to ensure the stud is a snug fit in the head. There's more chance of stripping the thread out of the head as the bolts thread is undersized to allow nuts clearance.
www.z1enterprises.com
Z1 Ent on Facebook,
