Minimum Octane for High Compression?
- 79MKII
- Love Them Kaws!
18 Aug 2010 04:52
I've searched and searched and haven't been able to find a straight answer to my question, so here goes a new thread...
What's the minimum octane fuel needed when running high compression pistons (12:1 or 13:1, drag race type pistons) in our KZ's? I'm considering going to the higher compression pistons but I'm not sure if I can run on pump gas. Anyone have experience with this? Thanks
The Kaw List:
- TeK9iNe
- What did you do!?!
Re: Minimum Octane for High Compression?
18 Aug 2010 06:41 - 18 Aug 2010 06:44
I've heard that the 12:1 and higher pistons are not very street worthy... but your choice of course.
@ FULL THROTTLE:
Compress. Octane Energy Efficiency
5:1
72
6:1
81
25 %
7:1
87
28 %
8:1
92
30 %
9:1
96
32 %
10:1
100
33 %
11:1
104
34 %
12:1
108
35 %
For typical carbureted / unmanaged engines DOHC.
GL.
@ FULL THROTTLE:
5:1
72
6:1
81
25 %
7:1
87
28 %
8:1
92
30 %
9:1
96
32 %
10:1
100
33 %
11:1
104
34 %
12:1
108
35 %
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Aug 2010 06:44 by TeK9iNe.
- 79MKII
- Love Them Kaws!
18 Aug 2010 07:02
Wow, that's a great chart, thanks!
It looks like the 10:1 pistons should have 100 octane minimum. I'm currently running my 10.5:1 pistons on 93 octane from the pump and it seems OK. Should I be running octane booster even with street pistons?
The Kaw List:
- mark1122
- Keep twisting it
18 Aug 2010 07:08 - 18 Aug 2010 12:09
The reason u have not got a straight answer is because there isn’t one. lol
i think the octane rating is more related to the psi in the cyl than a static compression ratio number. when u get near 200 psi static compression, I think u are near the limit for pump gas. Someone else may have a more accurate #. My 1200cc bike is 200 psi.
just because Wieso says a piston is 12:1 doesn’t mean it will be that after a build. every guy puts in dif combo's of cams and timing, and pipes. u and i have larger valves than a stock kz, so our 10:1 pistons are not the same compression ratio as the same motor with small valves. this is due to the sinking of the valve to get it to fit on a small seat. as the valve is sunk the chamber volume increases.
as u add a larger lift cam with more overlap, u decrease the compression as well. this is why u need a higher compression piston to run bigger cams, if u didnt u would not get as much bang for your buck.
modern motors commonly run 12.5:1 or more, but they have electronics to change the ratios(lower the psi in the cyl.) where and when its required. they have the ability to change the timing, exhaust back pressure, and fuel curve as well as the cam timing.they have a more eficiantly shaped comb chamber. 1 of the biggest things they have going for them is being water cooled. This means higher cyl pressures can be run without increasing the chambers temp.
If u try to run over 10.25:1 pistons on the street, u will forever be adding an octane additive, or dif fuel.
I think the 10.25:1 pistons are a safe # that they came up with to satisfy most builds. Some guys report pinging some don’t. it just depends on the combo. Which in the end depends on the psi in the cyl. The higher the psi , the higher the cyl temp. so the higher the temp the easier it is to detonate, or pre ignite.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 18 Aug 2010 12:09 by mark1122.
- 79MKII
- Love Them Kaws!
18 Aug 2010 07:35
That all makes sense. It reminds me of my days having personal watercraft. I had a Sea Doo that was highly modified with all the goodies. All you had to do on that 2 stroke twin to change the compression was change the domes on the head. I think it was a West Coast head if I remember correctly, but it had interchangable domes. I think they used to recommend specific octanes based on the compression, just like you mentioned. No cams or valves to worry about - much simpler.
My main question is can I run high comp pistons on the street and it doesn't sound like it would be worth it. I'd probably have to carry octane booster with me and I'm guessing that the reliability would suffer. Maybe I'll just stick with what I have....for now!
The Kaw List:
- mark1122
- Keep twisting it
18 Aug 2010 07:41
79MKII wrote:
Not on pump gas.
as for the chart above. i dont know how helpfull it would be in the real world.
u and i run 10.25:1 on 91 octane the chart says 100 ??
i have only heard of 1 guy that says he runs reg gas. have u heard of any??
i have never tryed myself.
before my last build i was getting some ping on 91. so i made some changes and it runs fine on 91 now.
Not on pump gas.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
18 Aug 2010 08:05 - 18 Aug 2010 08:06
On my last build, 1229cc at 10.5:1 c/r, I ran 87 once in a while and really didn't notice much of a difference. I used to think that 10.5:1 was close to stock anyway, but now I realize it's higher, so I always run the highest I can get, usually 91. I didn't see any signs of damage when I took mine apart for the new rebuild. I don't know of anyone running 87 on a regular basis though.
I recently realized and posted in another thread that I haven't checked the ignition timing on my bike. I use the stock electronic pick ups to trigger the msd ignition and don't think they're adjustable. I want to get a timing light and see where I am just to make sure things are where they should be.
Have you found that running slightly retarded helps with the detonation? Where should I set the ignition for best street performance? That's an area I've never really messed with. Maybe the multiple spark discharge helps make up for any ignition issues?
The Kaw List:
Last edit: 18 Aug 2010 08:06 by 79MKII.
- mark1122
- Keep twisting it
18 Aug 2010 08:52
79MKII wrote:
In reality, if u can run 87 octane some times , u can run it all of the time.
If u don’t get any ping with 87 why change/ the only reason to change would be peace of mind. It should not perform better with 94 octane, unless u make a change to the motor to take advantage of this higher octane. Like an ignition or cam timing change, to get more compression..
I have not played with timing either. I have had no reason to since it runes good. I have a Dyna 2000 . it has a more advanced electronic timing curve,(it advances the timing at a dif rate, not linear like a mechanical one) and is capable of an accurate timing setup.
I set the timing at 39*.theoretical if u have a better chamber design u can run less timing. The longer it takes for the burn to complete the higher the risk of detonation. So we may have changed things in the rate of burn. we have added more heat and a dome to get in the way of the burn. So theoretically we should need more timing. If it runs fine I wouldn’t worry about it. If I ever get to a dyno I will ask them to try dif settings. I don’t know if I could tell the dif on the street??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
18 Aug 2010 09:11
I was reading this on the web, and thought some of you might enjoy. I did not write this, I copied and pasted.
Link to article:
www.2strokeheads.com/tech-octane-detonation.htm
Article from web:
High Octane.. Does it REALLY Burn Slower?
Detonation: What is it, really?
Exposing the Myths of High Octane Fuel and the Definition of Detonation
It is often stated that " The higher the octane, the slower the burn" AND there is PLENTY of discussion on the internet that would support this statement... BUT... It is my opinion that this is a VERY common misconception among tuners and non tuners alike.
First, a little tech info..
Octane is the fuel's ability to resist detonation. The higher the octane, the higher its resistance to detonation.. This is understood.. It is not this article's intent to dive into how these octane numbers are derived. Suffice to state that different companies/countries derive these ratings quite differently. We can leave it at that for the time being.
Detonation occurs AFTER IGNITION... This is very important point in the discussion. MANY confuse/equate detonation to pre-ignition. Pre-ignition is just that.. PRE IGNITION and occurs BEFORE IGNITION.. So, detonation and pre-ignition are very different. Now, pre-ignition will generally lead to full blown detonation.. but it is its own entity and should be treated as such.
During the compression process, the fuel/air mix is being "squeezed" into a small area. Shortly after this squeezing process begins, ignition occurs. Ignition will start a flame kernal / flame front that will propagate and expand from the ignition source (generally a spark plug in a gasoline engine) outward towards the oncoming piston. Meanwhile, the fuel/air charge is still being compressed and forced into the combustion chamber area. This compression creates a pressure and this pressure creates heat. The flame kernal is also creating heat and aiding in the rapid rise is pressure.
Side note: The speed at which this flame kernal propagates is ,greatly, influenced by the head geometry, the amount of pressure surrounding it, the residual "mix" present and its chemical makeup.
OK.. back to the topic , at hand... So, we have a rapid expanding flame kernal, a fast approaching piston, and a fuel/air mix all occupying the same space and this space is getting smaller, VERY QUICKLY! This, my friends, is compression in an internal combusted engine. When the temp gets to a point that this fuel/air mix FULLY ignites, then we have combustion.
The key to proper combustion is to have it occur at the best time to extract the most energy from the fuel/air mix , at the best rod angle to impose the max amount of leverage on the rod, and to perform work on the the crank train via force.
IF the combustion process before or after the above criteria are met, then you still have combustion but it is not optimum combustion. For this tech article, we will only concern ourselves with combustion that occurs too soon with respect to the rod angle. This is what we will term uncontrollable combustion or DETONATION.
Detonation from Wikipedia:
Detonation is a process of combustion in which a supersonic shock wave is propagated through a fluid due to an energy release in a reaction zone. It is the more powerful of the two general classes of combustion, the other one being deflagration. In a detonation, the shock compresses the material thus increasing the temperature to the point of ignition. The ignited material burns behind the shock and releases energy that supports the shock propagation. This self-sustained detonation wave is different from a deflagration, which propagates at a subsonic rate (i.e., slower than the sound speed in the material itself). Because detonations generate high pressures, they are usually much more destructive than deflagrations.
Detonations can be produced by explosives, reactive gaseous mixtures, certain dusts and aerosols.
In more simplistic terms (via RK Tek): Detonation is when the charge is prematurely combusted due to very high heat/pressure. This is more of an explosion than a combustion and the forces produced from this are VERY large and are super-sonic in nature.
So, why is detonation so bad? After all, you have extreme pressure occurring at very high speeds. This should produce some serious force on the rod and spin that crank with much more authority. Yes, it produces forces that we would love to have acting on our crank, unfortunately, these great forces occur at the wrong time in the stroke. They occur at a rod angle that causes great STRESS on the crank, piston, bearings, and rod. So, this force becomes destructive vs. productive and since the force is so powerful, it WILL cause engine damage if not addressed.
So, how do we address and prevent the onset of detonation?
1) Proper combustion chamber design (i.e. geometry and volume) See RK Tek for this variable.
2) Proper ignition timing (adjust timing until optimum)
3) Proper Fuel amount and Octane (resistance to detonation) fuel.
OK, FINALLY, we get to fuel octane...
The octane rating of the fuel is directly related to its resistance to detonation. The higher the octane the higher pressures/heat the fuel can withstand before ignition. The rate at which this fuel burns has VERY little to do with the octane rating. The chemical soup of the fuel will determine the fuel's burn rate under IDEAL conditions. Since we KNOW that under combustion (active radicals, residual un-burnt mixes , squish action etc.) is NOT IDEAL, then this burn rate can not be properly established nor calculated. We do not need to know this burn rate because we will adjust our ignition and combustion chamber design to accommodate ANY burn rate. So, it is really irrelevant for us.
Does the higher octane fuel burn at a slower rate than lower octane fuel? IMO.. MAYBE, SOMETIMES, YES, and NO.. See above.. the rate of burn is dependant on many variables but to state that just because the octane is higher, then the burn is slower, is 100% incorrect.
Don't believe me?? Why should you? there are countless articles contradicting what I just said.. Well.. see an interview from the Sunoco Engineer below (I will highlight the best parts LOL)
Popular Hot Rodding Magazine, January 1998
By Scott Parkhurst
Octane is a measurement of a fuel's resistance to ignition. Ideally, the air/fuel mixture will ignite at the proper time and burn smoothly through the power stroke. The idea is that one powerful combustion of the air/fuel mixture is better than several randomly-ignited small flame fronts. When you can precisely control the point at which the fuel will ignite, maximum performance of the engine can be achieved, and power-robbing knock and ping will be eliminated. Knock and ping are a result of abnormal ignition, or multiple flame fronts colliding within the combustion chamber during the compression stroke.
All reputable fuel manufacturers determine the octane rating of their gasoline in the research lab using a special, dedicated single cylinder engine. Comparing the gasoline to a series of standard reference fuels in the test engine results in either a research octane number (RON) or a motor octane number (MON) depending on a set of operating conditions. The RON is determined with the test engine operating at 600 rpm, at standard barometric pressure, and the intake air temperature set at 125 degrees Fahrenheit. RON is primarily used to address part-throttle knock and ping problems. The MON addresses wide open throttle operation and is determined with the test engine spinning at 900 rpm, also at standard barometric pressure, and the intake air temperature pumped up to 300 degrees.
The best predictor of a fuel's performance in a street/strip machine is the Anti-Knock index (AKI). This is simply the average of the RON and MON numbers, or (RON + MON) / 2. Most all octane ratings posted at the pumps are determined by this AKI formula, and are the minimum values you could expect to see. The minimum octane requirement
of your engine is determined by several variables besides the compression ratio. The engine and cylinder head configuration, air/fuel mixture, timing, coolant temperature, atmospheric pressure, relative humidity, and ambient air temperature will also affect the octane required to make your mill produce maximum power.
The burn rate of a fuel is a measurement of the time required for complete combustion of the air/fuel mixture. The notion that octane ratings affect the burn rate of fuel is about 180-degrees from reality; burn rate is a function of several variables, and the two are completely independent, although there is generally a correlation between octane ratings and burn rates.
To give you a good example of this, we contacted Jim Wurth from Sunoco Race Fuels. He explains, "A perfect example is Sunoco Maximal, which is our fastest burning fuel, and coincidentally one of Sunoco's highest octane fuels at 116 (R+M) / 2. A lot of Pro Stock teams rely on Maximal for those sub-seven second runs. When they are turning 9,000 rpm or more, the fuel has to burn pretty quickly to achieve complete combustion".
Octane boosters offer little help in the quest for higher octane. Most popular street-legal octane boosters claim increases in octane ratings up to five points, and those boosters intended for off-road use only claim up to seven points. That's a lot of octane to hope for simply by pouring an additive in a tank. Sunoco told us that before they launched their GT-100 Unleaded retail pilot program, they wanted to be sure that a 100 (R+M) / 2 octane street legal fuel would be of value, and that enthusiasts would not be able to get the same (or better) results using an octane booster. Nine of the most popular retail octane boosters were put through a series of tests to determine where the consumer could get the most bang for the buck. The test results were verified by an independent testing facility, using several brands of regular unleaded and premium gasolines, just to make sure everything was legit.
According to Mark Borosky, Vehicle Test Engineer for Sunoco,"Of the nine octane boosters tested, none showed a significant increase, and one actually lowered the octane number of the test gasolines."Testing repeatedly showed a maximum increase in octane of 3.5 points by only two of the six street legal octane boosters when the recommended treatment rate was blended with lower base 87 octane gasoline. The best the remaining four products could muster was less than a one point increase. "While clearly no one would actually use an octane booster in a low base octane fuel, we wanted to give the manufacturers the benefit of the doubt relative to their claims of five-to-seven point increases," explained Borosky.
When tests were performed using 93 and 94 octane fuel, even the two best products from the previous tests produced a disappointing 1.5 to 2 point maximum increase. The remaining four street-legal octane boosters showed less than a .5 point increase. Those products designated for offroad use only didn't fare any better than the street-legal products. Subsequent tests where the dosage of octane booster was doubled, tripled, and even quadrupled produced only minimal improvements in octane, regardless of the base octane number of the test gas. In fact, quadrupling the treatment rate of the most powerful additive produced only a 3.5 point increase in octane when added to 93 premium, resulting in a cost of $3.25 a gallon.
An alternative path to octane euphoria is to blend gasolines of different octane levels yourself. It's easier than you may think, safe, and the results are predictable. The formula for mixing gasolines of the same type is pretty straightforward. When you mix a 50/50 blend of two unleaded fuels, simply average the two octane ratings to determine what's in the tank If you mix 94 and 100, you get 97. The same generally holds true for leaded gasolines, assuming the lead content is
nearly equal.
Blending a leaded fuel with unleaded, however, pushes the octane up a bit more than the math would suggest, due to the effect of the lead. Just a gram or two of lead blended into the unleaded fuel will raise the octane number significantly. Commercial leaded racing fuels contain anywhere from a trace to six grams of lead per gallon. If you were to mix 50 percent 110 octane leaded fuel with 100 octane unleaded, you would actually end up with an octane number around 106 to 107. Keep in mind that even the smallest amount of lead or leaded gas line with unleaded, could spell the end of your catalytic converter or oxygen sensor. The same holds true for using octane boosters intended for off-road use only. A word to the wise, check for any lead content in all the additives you might mix with your unleaded gasoline. And check with your state emissions regulations for street use.
We asked Sunoco's Wurth about using aviation fuel in an automobile engine. He was emphatic when he said, "Don't do it. Even though Sunoco is a major producer of aviation fuel, this fuel is specifically blended for aircraft engines. Aircraft operate under very different conditions than automobiles, and the fuel requirements are quite different as well. Aircraft engines generally.... run within a very narrow rpm range. There's no need for transient throttle response in an airplane because after the pilot does the initial engine run-up, the throttle is set in one position and the rpm doesn't normally change until landing. Also, airplanes fly where the air is cold and thin, and the atmospheric pressure is low. These are not even close to the conditions your street machine will see on the ground. Also, since most piston-driven aircraft cruise at 3,000 rpm or so, the burn rate of aviation gas is much too slow for any high performance automotive applications."
What is it that makes race gas so different? What's it made of? Sunoco tells us their GT PLUS 104 octane unleaded race gas is only 15-20 percent traditional gasoline, and about 85 percent additives! Actually there are about 120 different chemicals in GT PLUS. One reason it isn't street legal is the high oxygen content. The EPA requires that the oxygen content of a street legal fuel cannot exceed 2.9 percent. GT PLUS is about 3.5 percent oxygen. This fuel is light in weight at only 6.14 lbs-per-gallon. The high oxygen content improves the octane, and when the induction system is properly calibrated, this fuel will help make additional horsepower. The high oxygen content has a supercharging effect, since 3.5 percent oxygen is the equivalent to about 17 percent more air. Different fuels can actually alter horsepower 5-to-10 percent or more.
We wanted to to know more about the different types of race gas Sunoco had, and didn't realize there were five different types of racing fuel alone.
GT-100 Unleaded, is a clear fuel with a pump octane of 100, and will handle compression ratios of up to 12:1, and is street legal in all 50 states.
GT PLUS, is also unleaded, and is rated at 104 octane. It is suitable for compression ratios up to 14:1 and is colored light blue. It will not harm oxygen sensors or knock sensors in computer controlled engines. It is not street legal.
STANDARD, is a leaded fuel rated at 110 octane, is colored purple, and is intended for drag racing, road racing, and race boats.
SUPREME, is also a leaded fuel and is dark blue. It was developed to help resist vapor lock and meet the demands of sportsman, modifieds, offshore powerboats, and endurance racing where engines regularly run in excess of 7000 rpm.
MAXIMAL, we mentioned earlier, is colored red, has 116 octane, and is leaded. It is intended for exceptionally high performance applications like Pro Stock where extremely high cylinder pressures are common. Its extremely fast burn rate is satisfactory where rpm exceeds 10,000.
Now that you're an expert on gasolines, you probably would like to know where to buy and store the stuff. If you are fortunate enough to live in the mid-Atlantic states, you can take advantage of Sunoco's GT-100 Unleaded retail pilot program and get 100 octane race fuel at pumps located at select Sunoco stations. The rest of us have to purchase from local speed shops, at race tracks, or directly from Sunoco distributors.
When you plan on buying fuel in quantity, say a 55-gallon drum, you'll be happy to know that racing fuel has a shelf life of about a year, if you store it properly. The container must conform to all safety standards, and should be made from metal or polymer. Make sure the container is opaque and solid in color. The white plastic jugs we see at the track should be used for short-term storage only. They let in sunlight, which will affect the fuel. The lead in leaded fuel and other chemicals in unleaded fuel are photosensitive, and will dissipate if they am exposed to the sun. Keep any container tightly sealed to prevent evaporation.
So, the next time somebody tells you that higher octane fuel burns slower, just refer him to this article.
© Copyright 2006. 2StrokeHeads.com Disclaimer
Link to article:
Article from web:
By Scott Parkhurst
nearly equal.
- sebastian 34
18 Aug 2010 11:43
Raising static compression generally speaking improves torque and consequently power at low/middle RPM range. At a point, will actually prevent the ability of the engine to rev-up, so in this case the way to get more maximun power is making the engine able to rev; that (besides detonation) is the limit to raising static compression. Besides, when rpm rises, the actual pressure in the combustion chamber also rises due to the resonance effect of the fuel+air mixture and exhaust. I think that raising static compression as a way to make power is overrated. Regarding the 2-stroke engines, when in the case of trhe sea-doo you change combustion chambers you not only change static compression but chamber shape and squish, being setting squish a way of making practically free-power in two stroke engines.
Sorry for my poor english but couldn´t resist to post, LOVE this kind of threads.
'81 z1100B1 - '97 TL1000S
- larrycavan
18 Aug 2010 17:13 - 18 Aug 2010 17:18
79MKII wrote:
I don't believe the octane booster is actually effective. I tried it on various engines over the years at the suggested ratios. All it seemed to do was give the plugs a funny color.
Many racing pistons have top ring up closer to the dome. The top ring land is thinner than a street piston. If detonation takes place, the pressure can be enough to distort and break a chunk off that ring land.
Even with the domes cut down to street compression, the situation can still happen.
Stay with street pistons at 10.5 ratio or below with the type of fuel we have today.
Here's one that was cut down from 13:1. It was a vintage 80'a Wiseco 1166 piston. Click each pic for a blow up version.
Pistons had 5 passes at the drag strip at full compression before they were cut for street use. They had 300 miles on them when this one gave up. Fuel was 93 octane from a convenience store. Valero brand gasoline.
www.flowbenchtech.com/porting/CRH/piston.htm
Larry C
Larry C
Last edit: 18 Aug 2010 17:18 by larrycavan.
- 79MKII
- Love Them Kaws!
18 Aug 2010 17:25 - 18 Aug 2010 17:26
Sebastian - you're English is great - wouldn't have noticed that it's not your first language if you hadn't mentioned it. Thanks for the info.
Larry - that poor piston is scary looking. I'm sure the cylinder didn't look too great either! I think you guys have talked me out of going with the high compression pistons. Great information.
The Kaw List:
Last edit: 18 Aug 2010 17:26 by 79MKII.
