CARB CLEANING TROUBLE
- at20
please help me im new and i been at this all day
i have a pic of where the gas is coming from below
1976 kz400
- Thank you received: 2098
Am thinking float valve and/or float function failure, for whatever reason, whereby fuel is rising too high inside the float bowl.
Hoping an aftermarket in-line fuel filter was fitted before allowing any fuel to enter the freshly cleaned carbs.
Excess fuel is supposed to escape from the overflow nipple on bottom of float bowl, usually through a tube routed to exit underneath the bike.
Perhaps the overflow circuit is clogged.
Would sniff-test crankcase oil, and check its physical condition, to determine whether fuel has entered the crankcase and contaminated/diluted the oil. If so, should change oil and filter, and correct the problem before allowing any more fuel into the carbs.
- at20
1976 kz400
well my bike already had 2 in-line fuel filters on the lines before the gas gets to the carbs . i do have hoses coming from the flaot bowls and i thought gas would come out a lil but on the side that leaks nothing comes out the hose its just a lil stream that shoots out the hole ing the back. my book calls it an Air Jet. would it come from there it the overflow nipple is clogged
would it come from there it the overflow nipple is clogged --- I think so, but would suggest awaiting more certain advice from another having hands-on experience with these particular carbs.
Here's a diagram that's probably similar to the carbs at hand. But it doesn't show a float bowl drain screw or an overflow nipple.
[May click on image to enlarge view.]
One model has dual fuel inlet lines.
The other model has a single fuel inlet line.
There are likely internal differences between the carb styles.
If not already done, might want to take a look at the carb diagrams in kawasaki.com.
Click here > Navigate kawasaki.com
Click here > www.thegsresources.com/gs_carb_05.htm
- at20
- at20
1976 kz400
- at20
1976 kz400
so are saying its best if i wait and get other opinions ? i mean that might be it but im not sure cuz i didnt have a problem before. i just dont understand what would make it do that .
Am pretty sure fuel rising up into the carb would escape through the air jet, and likely other places as well, such as into the crank case.
What was the earlier diagnosed carb problem that prompted disassembly?
On which carb is fuel coming out the air jet? Or is fuel coming out the air jets on both carbs?
Usually it's a float valve and/or float function issue that causes excess fuel being allowed past the float valve into the float bowl.
Some of the many reasons could include such things as failure to keep the same float needle with its same needle seat, or installing floats upside down (as possible in some carb designs), or float damage such as leaking or bent, or float sticking/hanging, or mal-adjusted float tang, etc.
so cant i just try to blow out the over flow nipple with air after i take the bottom bowl off. i checked the hose and its clear so ill have to check that next
Might help clear a blocked overflow circuit.
Even where an overflow circuit is correctly functioning, it doesn't cure the problem of excess fuel being allowed into the float bowl.
