Oversize Piston Kits...
- beefsquasher
As you well know, an air-cooled aircraft motor is very different from these engines. Show me an aircraft motor that is an inline four similarly sized to the KZ and spins to 10000 rpm.
Asking you guys for information and advice constitutes a very important part of my research. I respect and trust just about everybody's input on this site.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- beefsquasher
PLUMMEN wrote:
the 1197 in a stock block will run much cooler than a bigblock motor due to no cooling passages between the sleeves on the bigblock,my 1327 is not ridable on hot days around town.
1197 with the right sleeves has plenty of meat in the cylinders,i dont agree with the 1260 in a stock block but some people seem to like it.
If both Larry and Plummen say it, I believe it...
I'm sold.
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- 79MKII
- Love Them Kaws!
- Thank you received: 43
This had me thinking earlier today that maybe the way to go would be around 1200cc or smaller but with HIGH compression. Sure sounds like I was on the right track.
My favorite set up yet was the 1075 kit (high compression) with an old Denco pipe. I have never ridden a bike that ran so perfectly and crispy. I guess I've learned the hard way that bigger isn't always better. Both the 1229 kit and the 1260 kit are 10.5 to 1 compression (street). I'm guessing that the 1260 still probably puts out more HP than the 1075, but that smaller engine sure felt faster.
The Kaw List:
- PLUMMEN
- Thank you received: 104
i like big bore motors mostly because im too damn lazy to shift all the time,just tap the throttle in any gear and just hang on as the train leaves the station! :woohoo:
- larrycavan
- Visitor
OK - just a quick note from my very recent personal experience (today!). After moving up from a 1075cc to a 1229c and finally this year to a 1260cc (stock block btw), I have been a little disappointed in my bike because it seems to heat up a lot more than even the 1229 did last year with the same block.
1075 is still the most bang for the buck. Use a shim on top cam and save a pile of money on retainers, buckets, sleeves, double bore job...... Just makes sense for a moderate budget street bike.
Spend the money on all new cam chain components and a good rack of carburetors. AND I DON'T MEAN BS34's :laugh:
- baborz72
- Not enough hours!
It'll go...or...It'll blow!
- 79MKII
- Love Them Kaws!
Let's say you have a re-sleeved stock block and the cases have been bored to match the sleeve OD. What if you want to go to a sleeve with a smaller OD....let's say back to stock, for example. Can you run that smaller sleeve with the bored cases or is there no going back?
The Kaw List:
- PLUMMEN
- DoubleDub
- Visitor
I think when the 900 cases are bored for the 1000 cylinders they can go back to 900 cylinders, but I'm not positive.
- DoubleDub
- Visitor
remember my little spray friend"copper coat"! :laugh: spray it on both sides of base gasket and youll be fine
Just ignore me. Here's your answer.
- PLUMMEN
- DoubleDub
- Visitor
