Engine popping
- customkz1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If its all the time, then could be a serious air leak somewhere.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- customkz1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- TeK9iNe
Have you tuned the mixture/air screws?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
Since you mentioned intermittent....
Points/condenser or Dyna E.I. ignition?
If P&C, when was the last time you
changed
Timing Advancer spring weak/sticking//lubbed?
Have you gone through all the electrical checks/measurements depicted in the manual?
Engine frame ideally grounded?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
- TeK9iNe
Might aid diagnosis to add a little choke while riding to see whether it affects the popping.
Ah yes! I always forget about the magical check lever, the choke.
If it gets better suddenly then you were likely lean. If it bogs right down, then you are too rich. A little bog with the choke on is normal, it shouldnt blubber and sputter though.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- customkz1000
- customkz1000
- customkz1000
- TeK9iNe
I had the carbs rebuilt. Bead blasted, ultrasonic cleaned, and oversized jets for the header and the carb pods.
Without the bike its very difficult to just "jet" a set of carbs correctly. There are lots of different perameters in engine operation and air/fuel volume requirements that affect wether to have slightly leaner or richer jets for the different carb circuits.
Try pulling your air filter out, and see if the problem goes away/improves, then you know Otto was right, I mean "ehem", you are too rich on the mid/low circuit.
If it gets flat/worse, your too lean.
To do a basic tune on the mixture screws, turn all of them 1/4 turn in or out and listen/watch the rpm. If the rpms go up, continue... turn them all more. At some point the rpm will start to drop again. Your trying to find the high spot/max rpm.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
