- Thank you received: 1
KZ750 not running correctly.
- Ituen
- Rider
07 Jul 2010 18:25 #380883
by Ituen
1982 KZ750 E
Kawasaki Rider
KZ750 not running correctly. was created by Ituen
My bike was running fine on the 4th of July. I took it out tonight and it sounded different when I started it. It slowly revs to redline, but doesn't feel as strong. It won't go over 60 mph. The fuel light was on and I stopped and got gas. I noticed strands of the exhaust insulation coming out of the megaphone. Any ideas before I drop it off at my mechanic?
1982 KZ750 E
Kawasaki Rider
- asevans
07 Jul 2010 18:29 #380885
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
Replied by asevans on topic KZ750 not running correctly.
make sure all the cylinders are firing. check your exhaust pipes.
1978 Z1-R Project
- bountyhunter
- Thank you received: 337
07 Jul 2010 22:16 #380964
by bountyhunter
Replied by bountyhunter on topic KZ750 not running correctly.
Sounds like a clogged main jet.
- Ituen
- Rider
08 Jul 2010 04:10 #380980
by Ituen
1982 KZ750 E
Kawasaki Rider
Replied by Ituen on topic KZ750 not running correctly.
I'll check it out after work. The gas tank was recently coated internally by a shop. The carbs were also cleaned a few weeks ago.
1982 KZ750 E
Kawasaki Rider
- djturnz
- Thank you received: 5
08 Jul 2010 07:17 #381013
by djturnz
1982 KZ750 (4) LTD
Replied by djturnz on topic KZ750 not running correctly.
If it were a car, I'd say clogged catalytic convertor. Since you are seing strands of muffler packing, maybe your muffler is clogged.
1982 KZ750 (4) LTD
- Ituen
- Rider
08 Jul 2010 08:45 #381022
by Ituen
1982 KZ750 E
Kawasaki Rider
It's only a few "hairs" here and there. I'm going to take the V&H megaphone off and take a better look at it. (I think the rivets need to be drilled out to replace the packing).
1982 KZ750 E
Kawasaki Rider
- bountyhunter
08 Jul 2010 12:01 #381086
by bountyhunter
Do you have inline fuel filters? If not, you can look forward to lots of incidents where it suddenly starts running crappy....
- Ituen
- Rider
08 Jul 2010 12:45 #381107
by Ituen
1982 KZ750 E
Kawasaki Rider
I don't know, I have to follow the clear line to the carbs.
1982 KZ750 E
Kawasaki Rider
- bountyhunter
08 Jul 2010 18:19 #381168
by bountyhunter
Clear fuel line should get tossed. You need real fuel hose. That clear stuff causes no end of problems.
- Ituen
- Rider
09 Jul 2010 12:59 #381284
by Ituen
1982 KZ750 E
Kawasaki Rider
What kind of fuel hose should I replace it with? Something with in inline filter?
1982 KZ750 E
Kawasaki Rider
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
09 Jul 2010 19:37 #381378
by ready2ryde1985
84 kz 700 a1
82 kz550 ltd
Replied by ready2ryde1985 on topic KZ750 not running correctly.
1/4 inch and i like the glass cleanable screen high flow inline filters you can find booth on ebay or z1 has good stough to.
I have 1/4 inch blue see threw line.
and a long h.d glass fuel filter.
love my pingal high flow pet!!!
84 kz 700 a1
82 kz550 ltd
- Ituen
- Rider
10 Jul 2010 04:00 - 10 Jul 2010 12:00 #381430
by Ituen
1982 KZ750 E
Kawasaki Rider
I have a "blue see-through" line, but no filter. I have to put one in. I took it to my mechanic. It was the fuel tap. I had it pointed to the "ON" position. He said I should have it pointing at the "PRI" position. Once we did that and I cleared it out, the power is back! I rode it around the block and it runs great. Thanks to everyone for all of your help.
1982 KZ750 E
Kawasaki Rider
Last edit: 10 Jul 2010 12:00 by Ituen.
