- Thank you received: 82
Advertised Drop In Cams NOT Dropping In
- larrycavan
- Visitor
On every one, it's #4 exhaust and #1 Intake tappet bores where they rub. They rub he valve cover bolt hole boss pretty hard.....
On another set of .400" lift cams, the sprocket bosses were thicker than normal and rubbed in the cam chain tunnel.
So watch out if you're buying drop in cams. Looks things over very carefuly. Q.C. [like most everything these days] ain't what it used to be...
- testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Motor Head
- Thank you received: 391
- bountyhunter
- Thank you received: 337
What a conicidence, same story for the electronics industry, auto makers, and every other business I know of.:laugh:Larry, I have no experience with drop in cams, but I do have a lot of experience working in machine shops. All I will say is that when the sh!t hits the fan, the first thing to get dropped is the QC.
- porchev914
- Thank you received: 19
FRANKEN Z!
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- testarossa
So Larry, if we shoot you a pm when we're ready to buy cams, then you'll steer us straight, right? I wouldn't expect you to trash talk a company publicly. You are in a different position that most of the members here.
2004 ZX-10R
Angola, IN
- larrycavan
- Visitor
All I can say is check things close guys. You guys with the maching shop experience are right on top of the situation. It's exactly like you described it when you pull the parts out of the box.
MV Agusta is my dream company! What I wouldn't give to be able to move to Italy and work for those people
- PLUMMEN
- Thank you received: 104
- APE Jay
- Banned
- Thank you received: 58
The first attempt was a little too much and the back side of the flange would hit the head on some castings. It was adjusted shortly after and is not now a problem.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
I would think if the lobes are hitting the head, I would check the Valve to Piston Clearance for sure. (shouldn't be done with motor assembled)
Oh what the heck, the only thing you are risking is some New Valves, Gaskets, Labor (and/or) Piston & Head damage.
Whats In Your Wallet?
- testarossa
ive always believed in clearancing the cam bucket area anytime a head is apart anyway for possible future buildups,saves headaches later when you have a motor broke in and want to wake it up a little
Hey Plummen,
Could you post some photos or info for those of us who might be interested in clearancing for the future. I'm certainly capable of figuring out the clearance when I do get my cams, but admittedly, I'm a newb to these motors, so for the sake of us newbs, where and how much clearance. It just so happens that I could do this right now since I have my motor apart. I will probably assemble it in the next week, so I need to decide soon, if I want to modify.
Jay, that's good to hear that the tolerance modification was made with some justification. Anyone with a manufacturing background will acknowledge that this is normal. You make incremental revision changes toward a final, polished, finished product that works. However, normally, this will happen "behind the curtain" and the end consumer shouldn't be subjected to prototype trials. Sadly, as said by bountyhunter, and I can back his statement up. In today's world, as a consumer, you are often the guinea pig. If you have ever purchased a first year model car, then you know what we are talking about.
I think that the main thing to take from this thread is the very important point that Larry raises. If you put a part into your bike that doesn't have an OEM Kawasaki label on the package, then you had better check it out to make sure that it functions properly. Porchev914 highlights a possible tragic situation. KZR member buys aftermarket cams for his bike that are sold as "drop-ins", so he drops them in without ever checking anything. Then he starts the bike for the first time, and hears a horrific grinding noise, and kills it. Upon pulling the oil pan, he discovers loads of metal shavings and decides to rip apart the whole motor to see what's wrong. Just that simple decision to split a case could be enough to cost an average guy a whole year of riding, and possibly be the reason that his bike ends up for sale on CL with "carb problems".
2004 ZX-10R
Angola, IN
