heads w/ wrong cam caps ?????
23 Jun 2010 17:13 - 23 Jun 2010 17:16 #377798 by trab
heads w/ wrong cam caps ????? was created by trab
Hi,guys quick question, cylinder head with wrong cam caps,there's not enough clearance for proper oiling to top end. now the question can I polish my cam shafts to get proper clearance for oiling, kinda like they do crankshafts in cars using plastigauge ..........thanks in advance for all help...
Last edit: 23 Jun 2010 17:16 by trab.
23 Jun 2010 17:30 #377800 by T_Dub
Replied by T_Dub on topic heads w/ wrong cam caps ?????
The cam journals are machined while the caps are bolted on. So if there's not enough clearance it means you're out of round. Not a good idea to polish down your cams, because chances are you'll have too much clearance out the sides or somewhere.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • larrycavan
  • Visitor
23 Jun 2010 17:45 #377803 by larrycavan
Replied by larrycavan on topic heads w/ wrong cam caps ?????
What kind of head is this?
23 Jun 2010 17:51 #377804 by Old Man Rock
Replied by Old Man Rock on topic heads w/ wrong cam caps ?????
I'm not getting this either... Pictures?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
23 Jun 2010 18:00 #377808 by T_Dub
I just assumed he meant ones that didn't come with the head he has.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • Motor Head
23 Jun 2010 18:01 #377810 by Motor Head
Replied by Motor Head on topic heads w/ wrong cam caps ?????
You either need the caps for that head, or take it to be bored along the cam bearing journals. Otherwise look for a complete head, used.
  • larrycavan
  • Visitor
23 Jun 2010 19:23 #377838 by larrycavan
You gave the correct answer Tyler. The head might well be fixable without too much difficulty.
23 Jun 2010 19:46 #377856 by kawsakiman
Replied by kawsakiman on topic heads w/ wrong cam caps ?????
what does something like that cost?
i have two extra j heads without caps.good info to keep in my back pocket for future use.
well matching caps that is.
24 Jun 2010 04:48 #377893 by T_Dub
Depending on the amount the bore is out, it may be able to be line honed. Otherwise they have to be machined. It's an area of your engine that needs to be veeeeeery accurate. I'd imagine its possible to get a set of caps that match your head so poorly that they would be impossible to match. Chances are that Ma Kaw used a very accurate horizontal milling machine for this process.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • Motor Head
24 Jun 2010 07:01 #377906 by Motor Head
A machine shop would be able to give you a estimate on cost. They will have to remove some material from both the head and the caps, were they come in contact to each other. Then either "Align Hone" or "Re Bore" the camshaft bearing journals, this may end up taking a larger outside diameter set of bearing shells. All doable but then there is the cost of the valve job, cleaning, parts, maybe milling for straightness on the head gasket area, etc.
Better be fond of that head, as I would say you would be approaching $500, parts & Labor.
  • Motor Head
24 Jun 2010 07:56 #377922 by Motor Head
cgi.ebay.com/ebaymotors/KAWASAKI-LTD-KZ1...&hash=item5186b2b160
This is a low mileage head on Ebay. I think you had "J" Motor in your post. If it won't open in your browser, just use the Item #5186b2b160 in Ebay's search box. You can ask for some better photos.
24 Jun 2010 11:16 #377959 by APE Jay
Replied by APE Jay on topic heads w/ wrong cam caps ?????
If the caps are not too far out, a few strokes with a hone will make it work. Sunnen has a mandrel for doing those heads.
