VANCE AND HINES
07 Apr 2006 15:16 #37640 by MBFMGP
VANCE AND HINES was created by MBFMGP
I JUST BOUGHT A BIKE WITH A V&H DRAG EXHAUST. IT HAS A BAFFLE IN IT
ANYONE KNOW HOW TO REMOVE THE BAFFLE .
GUY I BOUGHT THE BIKE FROM SAYS ITS JETTED TO RUN WITHOUT IT
Post edited by: MBFMGP, at: 2006/04/07 18:21
07 Apr 2006 15:24 #37643 by KitNYC
Replied by KitNYC on topic VANCE AND HINES
WHY ARE YOU YELLING?
Is this a special electrical exhaust? If not, you might have better luck in a forum other than electrical...
In all seriousness, ask in the appropriate forum, try typing without your caps-lock, & add your bike & location info to your sig.
I don't actually know anything about baffles in a Vance & Hines, but keep in mind that it's likely to be loud enough to get you a ticket if you're using it on the street. (My little 400 was setting off car alarms before I put a baffle in it.)
Oh, welcome to the site btw.
Cheers,
-Kit
  • wireman
  • Visitor
07 Apr 2006 15:37 #37647 by wireman
Replied by wireman on topic VANCE AND HINES
there should be a screw or bolt in the end of megaphone.;)
  • Duck
  • e vica na i sau na ga
07 Apr 2006 18:36 #37689 by Duck
Replied by Duck on topic VANCE AND HINES
Where are you and what's you bike? Go to profile and put in your signature. The young guys can remember but the old farts forget where their glasses are when they're sitting on their noses.
If it's a KZ900/1000/1100
How about swapping for my old kerker that already has the baffle removed. Pipes are routed a bit more conveniently for everyday riding and it's SUPER LOUD and badass black! I'm an old fart and it's too loud for me. Plus the bke I'm building needs a drag exhaust to make up for it's shortcomings in other areas.
It's easy to confuse forums when posting. Have done it here. A good trick is to look at the light blue line just above your name. It tells you where the stuff you're typing will get posted.
-Duck
Post edited by: Duck, at: 2006/04/07 21:37
