Low compression on one cylinder
- MadPhil
I just did a compression check on my 1980 KZ1000 Shaft. Numbers 1, 2, and 3 were 135-140, but number 4 was 115 dry. Wet it came up to 140. As I understand it this indicates worn or damaged rings.
The odometer shows 8,600 miles. I bought it last summer as a fix-up/clean-up project. It ran when I got it, but not very well. I cleaned the carbs, replaced coils, did a "Wired George", and now it runs great. It was not stored well by previous owners; some rusty bolts, faded paint and decals, but overall not too bad. Transmission is smooth as silk.
Here's my question... is it unheard of for a KZ with only 8600 miles to have worn rings in one jug? Is it possible that the bike actually has 108,600 miles on it? I know these are good engines, but has anybody run one that far? I would think there would be more problems than this one has.
Thanks,
Phil
- Old Man Rock
- Thank you received: 225
Pull the plug and compare to the others... If rings are the problem for that cylinder, this plug should be oil fouled....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Also, dont do any tuning till she's burnin' hot as well!
If everything runs great, I wouldnt be too concerned, unless your a perfectionist with her :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
- porchev914
- Thank you received: 19
FRANKEN Z!
- MadPhil
I'm not real worried about it since the bike does run well. I'm just curious about the cause, and hoping I didn't buy a bike with 100,000 more miles on it than I thought.
How far can these beasts go, anyway?
- Thank you received: 2098
...just did a compression check on my 1980 KZ1000 Shaft. Numbers 1, 2, and 3 were 135-140, but number 4 was 115 dry. Wet it came up to 140. As I understand it this indicates worn or damaged rings.
Here's my question... is it unheard of for a KZ with only 8600 miles to have worn rings in one jug? Is it possible that the bike actually has 108,600 miles on it? I know these are good engines, but has anybody run one that far? I would think there would be more problems than this one has....
Imo should quit worrying about the compression figures, put at least 1000 miles on her, and then do another compression test.
"Standard" is 128~156 psi with 100 psi service limit.
Spec is less than 14 psi between lowest and 2nd lowest, so 115~135 isn't much out of spec anyhow.
The above figures are "ideal," and many of the large fours perform quite well with only 100 psi and more psi differential among cylinders.
If not already done, change the oil and filer, and RIDE.
- gane
[img][/img] 1977 KZ1000A1
- bountyhunter
- Thank you received: 337
- APE Jay
- Banned
- Thank you received: 58
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
