- Thank you received: 104
1980 LTD Street Head stock valves
- larrycavan
- Visitor
- larrycavan
- Visitor
- larrycavan
- Visitor
- larrycavan
- Visitor
- larrycavan
- Visitor
- larrycavan
- Visitor
- PLUMMEN
- Kraz1
- porchev914
- Thank you received: 19
FRANKEN Z!
- larrycavan
- Visitor
Larry, would you get those numbers from a 1st generation Kz head? Or even one that has had J motor valves installed?
Yes, all the KZ heads, 900 & 1000.
It's a valve size / throat size relationship along with the bowl that will mostly set the pace for the flow.
I've got to the point where if the stock 36mm valves are shot I will quite often just jump up to a J intake because with the shorter J valve it's not all that much more work to sink them where they need to be.
That in turn gives you more lattitude to play with throat size and taylor things for the way the guy rides the bike.... Hope that makes sense
On this particular head, the guy has some old police BS34 carbs. Not my favorite by any means but I completely understand budget restrictions so I just change strategy a bit for things like that.
As far as I'm concerned BP could use all the BS34's advertised on Ebay and plug the leak in the gulf with them..... :woohoo:
- porchev914
FRANKEN Z!
- porchev914
FRANKEN Z!
