- Thank you received: 10
Cheating Flywheel puller?
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- z1kzonly
- Thank you received: 540
But for thr Z1 & KZ900 engines, you can use a stock rear axle
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bountyhunter
- Thank you received: 337
- Kitten Tooth
Very nice,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- MDawnz1
- Thank you received: 27
If it is tight,
Don't over tighten and mess up your rotor,
When it's tight, if it has not "poped" off yet,
Whack the head of the bolt "flush" with a hammer.
1974 Z1a, still 903
- Fozzie
1982 KZ1000J
- larrycavan
- Visitor
So does anyone have a picture of what the engine looks like on the left side without the cover? Kitten Tooth, any chance of a pic or two? I will be replacing that little grommet that the wires pass thru this weekend and just want to prepare myself for what I will expect to see. Thanks!
Really a good idea to own a service manual if you're going to work on your own bike
bikebandit.com has all the fiche pictures for your motor with part numbers...
When you pull the cover there will be a starter gear, shaft and 2 washers.
Inside the cover is the stator assembly. You'll need an impact driver and allen wrench to remove it.
Wires plug in under the sprocket cover. Yank the foot peg, shifter, starter cover and sprocket cover, then the generator cover.
You can leave the clutch cable attached to the sprocket cover and just swing the works out of the way.
Have a good look at your clutch cable while you've got it apart. Good opportunity to lube the clutch adjuster worm gear while the sprocket cover is off and lube your clutch cable as well...
Nothing difficult about the job you're about to take on but it's always a lot easier if you have the manual...
- Fozzie
1982 KZ1000J
- jacoatl
Been trying to get the flywheel off, tried with rear axle, hammering , some heat, tapping the outside which resulted in cracking two of the magnets. Can I still use it, repair(glue)or is it junk?
Still haven't gotten the flywheel off and getting scared to hammer the axle any more and will go look for a ball bearing or order the tool.
Thank you.
- Kray-Z
- I need more power Scotty....
- Thank you received: 107
The proper rotor puller tool is heat treated high carbon steel - very hard and tough steel. I would recommend only the proper tool for these stuck on late model rotors. I use a special high torque 1/2" drive air impact wrench on the badly stuck on ones - short trigger bursts, followed by moderate tapping square on the end of the puller tool with a medium weight ball peen hammer. Don't strike the rotor itself. I've only had to use propane torch once (the first one I ever removed, the rotor had spun badly and both crank end and rotor were scrap metal).
Any damage to the rotor requires replacement - the thing spins at engine speed and is a critical part for engine balance and... your safety! When reinstalling the rotor, check and make sure there is no noticeable out of round, axial or radial run out as the crank is rotated.
