- Thank you received: 18
Top Fuel Factoids
- Kawickrice
14 Jun 2010 10:30 #375647
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Top Fuel Factoids was created by Kawickrice
Not sure if this is current or not but interesting just the same
Some interesting Top Fuel Dragster Facts.
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500. They have over half again as much horsepower in one cylinder as a Dodge Viper has in all ten. No one has ever successfully run one long enough on a dyno to get a horsepower reading; current estimates are right around 6,000 horsepower.
* Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. The fuel pump alone requires more horsepower to turn than the average street car produces.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* The 1.7:1 air/fuel mixture for nitromethane produces a flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissassociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After the run, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by running the car out of fuel. There is no way to cut off the fuel; the engine stops only when it blows or the tank runs dry.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's. To put this in perspective; a top fuel dragster, parked next to a Super Hornet on the steam catapult on the deck of an aircraft carrier, would be in the water and sinking before the Super Hornet was halfway down the deck.
* Dragsters reach over 300 miles per hour before you have completed reading this sentence.
* Top Fuel Engines only turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load. They only survive about 80% of the time.
* The redline is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second.
* The engine is entirely rebuilt every run, or every 900 revolutions. New pistons and rings, new rods, new rod bearings. Sometimes a new crank. The crew does this in about two hours between rounds.
* The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
That folks, is acceleration.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Mcdroid
- Gone Kwackers
- Thank you received: 317
14 Jun 2010 10:45 #375652
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Top Fuel Factoids
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- hocbj23
- Visitor
14 Jun 2010 11:02 #375654
by hocbj23
Replied by hocbj23 on topic Top Fuel Factoids
Gee, and just think,some people who drive those 4 wheeled bombs waiting to go off actually think of it as "sport".Ubba-ubba-ubba -not me.bj
- BSKZ650
- Thank you received: 14
14 Jun 2010 11:14 #375659
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Top Fuel Factoids
only one word...........DAMNNNNNNN:)
- Thank you received: 2098
14 Jun 2010 11:50 #375667
by Patton
Replied by Patton on topic Top Fuel Factoids
Very interesting! :woohoo:
Thanks for the post!
- PLUMMEN
- Thank you received: 104
14 Jun 2010 12:36 #375680
by PLUMMEN
Replied by PLUMMEN on topic Top Fuel Factoids
its actually closer to 8000-9000 hp,but they have a really hard time finding dynos that will hold it.pretty much the same motors run in top fuel dragboats
- PLUMMEN
14 Jun 2010 13:04 #375693
by PLUMMEN
- mark1122
- Keep twisting it
- Thank you received: 109
14 Jun 2010 13:18 #375696
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Top Fuel Factoids
Cool Thanks for the info.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- hocbj23
- Visitor
14 Jun 2010 13:26 #375700
by hocbj23
- Jack
- Thank you received: 7
14 Jun 2010 13:31 #375704
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic Top Fuel Factoids
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Jack
14 Jun 2010 13:36 #375707
by Jack
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- flht1997
14 Jun 2010 15:25 #375736
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic Top Fuel Factoids
I do a high horsepower unit in my small engine class. we talk about top fuel cars and the power they make. but i then switch to the Space Shuttle Main engine, which creates about 12 million horsepower, and its fuel pumps alone are about 9 times the power of a top fuel dragster. Then i have them research the Saturn V rocket which comes in about 38 million horsepower. I have never seen a shuttle launch and with only two more i guess i never will.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
