cam degree
- hocbj23
- Visitor
- richard head
- Banned
- keith1
- Thank you received: 2
No worries mate. The lengthy and highly entertainig tutorials will follow shortly. Sit tight.
why you waste your time on literary dribble that will be erased within 20 mins of your posting is something that questions your sanity.....doesnt the double wide need some attention with the spray gun?.....:laugh:
- hocbj23
- Visitor
- richard head
- Banned
why you waste your time on literary dribble that will be erased within 20 mins of your posting is something that questions your sanity.....doesnt the double wide need some attention with the spay gun?.....:laugh:
Only before your power washing.
hocbj23, I believe you have a J motor. That would answer your question. But will wait to see if anything has been missed. Are they stock cams ?
- Motor Head
- Thank you received: 391
Do you have adjustable cam sprockets? And a degree wheel/ dial indicator? Otherwise you will be installing per factory service manual by lining up marks.
- beefsquasher
You can fiddle around with the timing if you want (just remember to turn the engine over slowly a couple of times to make sure nothing hits). I set my stockers at 107-108 and picked up a bit of midrange. I currently run Kenny Harmon L1 cams at 104-105.
I have fooled around with the timing a bit, and it seems that unless you are wayyyyyy off (like a whole tooth) the bike will still run generally fine.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- hocbj23
- Visitor
- Motor Head
- hocbj23
- Visitor
- 9am53
BTW, like I said I did the same swap this winter...you will find at 3000 rpm the freight train will not hit as hard with the J cams, BUT at about 6000 watch out. BTW, do you have a new tach? the J cams don't have a tach gear
'84 GPz900r
'71 CB350
