Replacement valve sources ,'82GPz750
- mjg15
I will probably have a chance to pull the valve cover and check clearances in the next few days, just trying to get a source lined up early
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
- Thank you received: 337
I found new Vesrah valves for my 750 twin on ebay from a seller called rustyriders LLC. I think they were about $12 each which was a lot cheaper than Kawi.I have a feeling that I may have bent the valves in my 750. Any input on a good sources or type for replacements ?? OEM vs SS ?? Just a street motor so I have no special circumstance or requirements .
If you have to order Kawi parts, Z1 enterprises, babbittsonline.com, and bike bandit will order them for a discount off list price.
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- mjg15
Gotta scout Ebay for a bargain on some OEM gaskets too.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- bountyhunter
I hear Vesrah makes a decenty top end rebuild gasket set. I wasn't happy with the Athena kit I got. OEM is better, but pricey. I think if I had known I would have gone OEM for the head gasket and base gasket, and get a Vesrah set for the rest.That's not too bad.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mjg15
I think that I bent them by overrevving the bike. Most likely the exhausts. I had the carbs off and when I re-installed them one of the screws from an intake boot snagged the throttle cam on the carbs at full throttle. I was able to get to the kill switch, but the damage was most likely done. Unfortunately I had just gotten the bike and was unfamiliar with it. I've been thru all the external stuff and cant get it to run smoothly on all 4 cyls. I've had the carbs cleaned ultrasonically, swapped all electrics for known good ones, new plugs and wires, 120+ psi compression on all 4 . All four run, but it wavers between them and never really runs well. Valcover comes off next. They may be tight, but I'm guessing very mildly bent(which I'm speculating will measure as loose?). It's a nice, clean bike and is much more comfortable than my 550's or 690 supermoto for two-up riding.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
- mjg15
Well sorry to hear about the damage. Hopefully its not to bad.
Well if I'm right and they are bent thats not great....but Im glad that I didn't crash !!
Some gaskets, valves, and a pair of underwear makes it a pretty cheap lesson !
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
