kz750 or gpz750 cylinders for a 650
- dnestell
- steell
- apeman
- Thank you received: 3
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- Lorcan
- Speed Loony
- Thank you received: 59
Post edited by: Lorcan, at: 2006/04/05 17:38
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- Lorcan
- Speed Loony
760cc - 8.69@162mph
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- steell
I wonder if the 650 block can be bored out enough for the 750 sleeves? I suspect that it could be, but I don't have any 650's to compare.
- 77KZ650
- Thank you received: 7
Looking at that picture just reminded me of something I was thinking about a while back.
I would think it could, the 880 kit by aries used larger sleeves than stock 750 sleeves, and I think it could be put in the 650 block too, but Im not sure.
Scott
07 MDP Rookie of the Year
- Mark Wing
Mark
Yorba Linda Cal.
- Dave Sloan
I think that the gpz750 has the hyvo type cam chain and not a simplex chain like a lot of the 650's have.
I think that there is a difference in the cam chain guies/ slippers between the two different style cam chains?
Cheers
Z650B2 - Injected
- steell
The 750 jugs fit the 650 cases with little work and the 880 kit should be able to made fit as the stude spacing is the same on the 650 and 750.
Mark
I was asking if the 650 cylinder block could be bored enough to fit the 750 sleeves, and was hoping that you still had both those blocks in the picture and would be curious enough to measure
Dave Sloan wrote:
AFAIK, all the 750's had the HyVo chain, and the 650's started using it ~1981I think that the gpz750 has the hyvo type cam chain and not a simplex chain like a lot of the 650's have.
Yes there is a difference in the slippers, but there seem to be a number uf 650/750 hybrids running around, so I figured that people must be using the 750 slippers on the roller chain without any problems.
- Mark Wing
Mark
Yorba Linda Cal.
