Time for replacement headers?
- Jodyb17
25 Apr 2010 16:15 #363172
by Jodyb17
1977 KZ 650 C
Time for replacement headers? was created by Jodyb17
My headers are in rough shape. What do you guys think? Grind off the rust and paint or are these toast?
1977 KZ 650 C
- keith1
- Thank you received: 2
25 Apr 2010 16:36 #363175
by keith1
Replied by keith1 on topic Time for replacement headers?
if its uniform rust...not flaky.....i would take a shot at painting them with hi-temp black.....i would try to find something to nuetralize what corrosion is left after sanding...its gotta hold up to high heat though....and pb blast those bolts holding them on....i m sure the more experienced in this area will chime in.....good luck...
- hocbj23
- Visitor
25 Apr 2010 17:14 #363180
by hocbj23
Replied by hocbj23 on topic Time for replacement headers?
Got some nice ceramic paints out today that seem to hold up well IF u get the rust off and prep the pipes. Much cheaper than new ones.bj
- bountyhunter
- Thank you received: 337
25 Apr 2010 17:36 #363183
by bountyhunter
Replied by bountyhunter on topic Time for replacement headers?
sand blast then powder coat.
- havakaw
- Thank you received: 27
26 Apr 2010 15:13 #363342
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Time for replacement headers?
I don't know if it's still out there,but I used a product called "Naval/Navel Jelly" to clean up some rust on some car parts a few years back.It did a good job to get most of the surface rust off.It just brushed on and then washed off.Also,to check for pipe integrity,you can take a pair of Channel Locks and GENTLY squeeze the pipes to see if they easily deform,and to feel for weak spots.If you punch thru,then yeah,it's time for new ones.Sand-blasting may be too heavy a medium and actually put holes in the pipes if you're not careful.
'80 KZ 750 LTD-H
- gane
- Thank you received: 1
26 Apr 2010 15:59 #363356
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Time for replacement headers?
Jody, Experiance is that the biggest prob. with rusted headers is at the bottom, where moisture collects, & contact w/speed bumps et;all cause "flattened" pipes. If this area is still "sound" I'd simply sand as much of the rust off as is feasable, & spray w/ your' choice of hi-temp. (mine's Dupilcolor's ceramic) If cosmeticly intrested, after 8-10 hours of use, re-sand & re-spray, usually after 3-4 repetitions most of the old rust dimples will dissappear as the "old" coats act as "seasoned " primer. If collecor area is weak/or has rusted thru, start shopping, luck G
- Jodyb17
26 Apr 2010 17:01 #363372
by Jodyb17
1977 KZ 650 C
Replied by Jodyb17 on topic Time for replacement headers?
Thanks for the advice guys. I will give refinishing them a shot after I check their integrity. I'll try the naval jelly before using a mechanical/abrasive method. I'll be sure to update this post with results.
1977 KZ 650 C
- kimsmith4807
- Thank you received: 4
26 Apr 2010 17:22 #363375
by kimsmith4807
1981 KZ1000-K1 LTD
Replied by kimsmith4807 on topic Time for replacement headers?
Mine too are showing their age (KERKER 4-1). Almost dropped the cash for a new system $$$. Got some direction from some other folks about shops that offer ceramic coating. Did some research and for about $125ish you can get something real nice. They sand blast and then apply the coating. Some companies out there offer up to a 3 year warranty on the coating as well. Do a search in your state and I bet you'll find guys who do ceramic coatings. It seems to be very popular.
1981 KZ1000-K1 LTD
- Jodyb17
03 Jun 2010 18:04 #373205
by Jodyb17
1977 KZ 650 C
Well here's how they turned out. Not bad for $30 and some elbow grease.
kzrider.com/index.php?option=com_kunena&...=11&id=363157#373203
1977 KZ 650 C
- Jodyb17
03 Jun 2010 18:07 #373208
by Jodyb17
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
03 Jun 2010 18:31 - 03 Jun 2010 18:33 #373224
by riverroad
Replied by riverroad on topic Time for replacement headers?
Looks good! I ran black painted headers for years, and the paint will burn off after a while. But using some aluminum foil and/or pieces of carboard to mask the engine, they ain't hard to touch up every once in a while. VHT is good paint, but I usually opted for cheaper BBQ paint.
Last edit: 03 Jun 2010 18:33 by riverroad.
- bountyhunter
03 Jun 2010 21:40 #373279
by bountyhunter
The VHT will last longer if you force cure it before running it. I hang the pipes on a coat hanger in the garage and take an industrial heat gun to the pipes inside and out.
