Starting Issues
- MKorcek
25 Apr 2010 09:03 - 25 Apr 2010 09:18 #363044
by MKorcek
MKorcek
1981 KZ 550 LTD (project)
Starting Issues was created by MKorcek
When I attempt to start my bike, I can get it to turn over, but when I release the starter, the bike sputters and dies. All withing about 2 seconds of releasing the starter. My wife has helped me try and start it as she has a Harley....but so far to no avail. Anyone have any ideas? I am thinking about pulling the Spark Plugs and takinga look at them.
Thanks
Also, I bought the bike off of a guy who bought it 2 yrs ago for parts. So he only started it a few times in those 2 yrs.
Matt
1981 KZ550 LTD
Thanks
Matt
1981 KZ550 LTD
MKorcek
Last edit: 25 Apr 2010 09:18 by MKorcek.
- Link14
- Thank you received: 6
25 Apr 2010 09:12 #363047
by Link14
Replied by Link14 on topic Starting Issues
One thing that I used to do that hurt my starting efforts with my 750 is twist the throttle to "help" start it. I can't see what carbs you have, but if you have a carb that doesn't have accelerator pumps, you need to keep the throttle closed to create the vacuum required to draw fuel through the pilot circuit.
Who knows, might help.
Good Luck
Good Luck
- MKorcek
25 Apr 2010 09:17 #363050
by MKorcek
MKorcek
Replied by MKorcek on topic Starting Issues
Sorry, I am still learning about that. I know that I do have the Res, On, Pri fuel toggle. So I know I have to have it in Pri for starting. But other than that, I am still getting there. I will take some more pics today and post them on my profile.
MKorcek
- otakar
25 Apr 2010 09:42 #363057
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Starting Issues
Do you use the choke?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hocbj23
- Visitor
25 Apr 2010 09:58 #363061
by hocbj23
Replied by hocbj23 on topic Starting Issues
I would also suggest using the choke.Kawis are notoriously cold natured and I use the choke even on a warm day when the engine is cold or mine sputters and dies as well.Might also pull the fuel valve out and be sure it isnt gunked up, and definitely replace the plugs if the bike has been sitiing up that long. May end up cleaning the carbs as well.bj
- MKorcek
25 Apr 2010 09:58 #363062
by MKorcek
MKorcek
Yes I use the choke. But still to no avail
MKorcek
- MKorcek
25 Apr 2010 10:12 #363063
by MKorcek
MKorcek
Being a Newbie, can I get the spark plugs at any auto store or do I need to go to a ATV / Bike store?
MKorcek
- bountyhunter
- Thank you received: 337
25 Apr 2010 10:24 #363067
by bountyhunter
Replied by bountyhunter on topic Starting Issues
I didn't find the plugs around here at Pep Boys, a bike shop will have them.
The starting problem sounds like a fuel issue. If the bike sat for a couple of years, the carbs are probably gunked up with oxidized gas.
- MKorcek
25 Apr 2010 10:43 #363080
by MKorcek
MKorcek
well i will try the spark plugs and some sea foam. I know the flasher needs replacing, ohm'ing out at about 3 -4. Book says should read 0.
MKorcek
- TeK9iNe
- What did you do!?!
- Thank you received: 28
25 Apr 2010 10:58 - 25 Apr 2010 11:00 #363085
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Starting Issues
Getting anything started after a long sit is very difficult.
Use a car battery, to let the starter have as much juice as it wants. NO, this will not blow anything despite what idiots say. As long as its 12Volts,(same as bikes system) its fine.
new plugs is never a bad idea. Before you put them in, make sure your getting spark by connecting them to the wire then holding the plug against the engine/ground. When you crank, you should see a nice blueish white spark on every revolution of the engine. Do this for all the wires.
Make sure oil is correct level.
Then pour about 1 tablespoon of gas into each cylinder and replace plug quickly.
Fire it up with full choke, NO THROTTLE, and turn the idle control knob on the carbs in a full turn.
If the bike fires (which it will, if you have spark and timing is correct) it will either keep running, or run a few revs, then die.
If it revs then dies, that means your carbs are all gunked up in the pilot/low speed circuits and need a real good cleaning.
Dont worry if the bike revs up loud and keeps running. It will do that for about 5-7 seconds on full choke, then the it will start to come back down, thats when you start to manipulate the choke a bit to get the idle where you want it. Once the bike reaches full temp, and the choke is off all the way, then you can set the main idle screw to wherever you want it.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 25 Apr 2010 11:00 by TeK9iNe.
- MKorcek
25 Apr 2010 13:19 #363130
by MKorcek
MKorcek
Replaced the spark plugs, poured gas into the cylinders like you said. The bike starts to catch and dies out a second or so after I release the starter. Carbs?
MKorcek
- otakar
25 Apr 2010 14:07 #363140
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Since the bike sat for a long time I would suspect the pilot jets to be clogged. This is a rather common problem with long term sitting.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
